2 of them were loose. You could easily turn one of them by hand. Hopefully that is the problem then!
The Definitive S2 Spark Plug Thread
This is a sticky topic.
The good book states 0.6mm (with tolerance permitted up to 0.7mm)Paul Nugent
Tryin out some Laser Platinum NGK PFR7B... only been in a day, but so far feels really responsive... but then after looking at the ones that i've taken out anything'l be better!
Anyone know anything more about these?
have i made some grave mistake...
JComment
not an easy one plugs. the standard plugs are rated very poor on some us forums with proven issues of broken electrodes etc.
i have at present bkr7e. working fine. gonna try another soon to see where it takes me. gapping is probly as important.Comment
If they have it'll be because NGK have given VAG a better deal than Bosch.
Years ago when plugs where changed every 6000 miles it was said that Champion gave plugs to BMC & Jaguar for free just so people then used their brand for servicing for the rest of the life of the car.
JohnComment
Stock plug is the same heat range as the bk7re, NGK orig number is PFR7B, if you must use NGK plugs then you want an 8 range.
Bosch plugs work best all round, the stock s2 plug is used as a performance plug on many cars, VR6T,1.8T's,RS4's,RS6's, Porsche etc etc.Last edited by audiman; 4 April 2010, 13:43.sigpic
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nmComment
look finesigpic
Audi UR Quattro
yea. look fine.
engine well maintained
btw, wouldn't the spark plug for the ADU / ABY must be the same gap regardless its brand name? and also same screw thread pattern?
I know Bosch is a well known spark plug, but i think its also difficult to grab one of those recommended Bosch plugs from my area.
Anyone that doesn't use Bosch, please share your experiences and also some pics of the plugs after replacing them to see how they burn...
Thanks.2002 A3 8L
2005 TT 3.2 Quattro
2007 A4 Avant B7 (hers)
2009 100 C4
2009 A6 Avant (hers)
2010 RS2
2010 S2 Saloon
2011 KTM SuperDuke 990 Olive GreenComment
NGK plug is NOT pre gapped like the Bosch plugs.
If you cant buy Bosch, just order genuine (they are Bosch anyway)sigpic
Audi UR Quattro
Been playing with sparkplugs after repeated failures of the F5DPOR's from GSF and main dealer ended up settling with BKR-8EIX from NGK.
I wouldn't touch denso Iridium's with a barge pole, I have seen too many heads written of because of them breaking up on FI cars.
BKR -7E's and 8E's copper electrodes are fine but need regular replacing and don't like high boost application unless you close the gap to smaller than factory 0.6mm. The benefit though if you are getting det, the electrode will deteriorate and cause missing under load before you melt your pistons.
Looking at trying a set of plugs soon that will hopefully allow for more ignition timing that we tried on a 1.8T last night on the rollers were we managed to get to 19 degree advance instead of 15 without det. only downfall is they are £38 per plug.UrS6 Stroker + HTA3586 =
To stop plugs coming loose try installing the plug, nip it down then back it off and then retighten to desired setting. The crush washer obviously compresses when you first install the plug, when the engine runs then everything expands and the crush washer gets squeezed a touch more, when all cools the tension from the washer may relax allowing the plug to come loose.
I also find on plugs that are not pre-gapped that closing the gap will ensure that the spark isnt blown away under higher boost loadings. So if your gap is normaly .025" set it to .020".Comment
