RS2'ed 3B motor: What's the DV of choice for the 360 HP range?
  • archiboy24
    • Sep 2003
    • 286
    Producing about 28 psi of boost with my set up. Is the 710N a suitable variant? Other options like Forge or the Bosch 110 sport valve?
    Also looking for similar advice on the N75 WGFV. I've read somewhere that the 'H' part number is the best out of the 4 or 5 versions of the valve. Can anyone confirm?
    Thanks,
    Ben
    Ben
    Calgary, Alberta
    Canada
    1991 CQ e//S2 w/ RS2 spec 3B 20vt
    Panther Black Metallic
    www.moda-architecture.ca
    The tip seems to be to use the 710n from the S3
    • stevieyid
      • Apr 2005
      • 2251
      28 Psi? Have you changed the internals etc? I think mine is running a bit less than that just wondering if i could get a bit more from it
      • s2_bo
        • Oct 2005
        • 6067
        710n from the RS6 is strongest iirc. But ether way if you want something different and longer lasting you could go for a forge valve or turbosmart etc etc.
        There is plenty of choices out there, all depends on your budget really..
        The stock N75 is fine according to most tuners, there is only very small differences between the different letters, mainly orientation of the connector.
        You can also use a Trbosmart WGFV or build your own, there is threads on here about it.
        91 S2 coupé - RIP
        98 S8 - Luxury barge
        • Rusty
          • 18953
          Forge 007 is a good option for the money although the sealing on the piston is just metal on metal between inlet and outlet. GFB do some really sweet DVs too. There's also the APR R1 diaphragm valve, American product so should be good money.c
          • archiboy24
            • Sep 2003
            • 286
            Nope. Stock internals, RS2 turbo, EM, injectors, 4.0 BAR FPR, 7A exhaust cam, RS2 FMIC, 3" DP, RS2 MAF, 3.0 BAR VMAP.
            Ben
            Calgary, Alberta
            Canada
            • archiboy24
              • Sep 2003
              • 286
              Thanks guys!
              Ben
              Calgary, Alberta
              Canada
              • T2Andy
                • 1903
                That does sound like alot of psi ,is this set up fine at that pressure i get worried when it goes about 22psi
                Is it the map which dictates what pressure you run obviously the turbo has to be capable .
                  Originally posted by archiboy24
                  Also looking for similar advice on the N75 WGFV. I've read somewhere that the 'H' part number is the best out of the 4 or 5 versions of the valve. Can anyone confirm? Thanks, Ben
                  Ben: I was going to point you to the article. It was from European Car mag. lskolnick on AudiWorld had posted it as four jpgs but he has apparently pulled them down (Red X's).
                  The 034 906 283H is for the C4 AAN UrS cars. "K" is for the RS2 ADU and the S2 ABY. The J was for the 3B. The article indicated that the H was best. I am running a K on my RS2'd AAN but, to be honest, there was very little difference and I have been thinking about going back to the H.
                  I'm going to be in Calgary on the night of Oct. 28th. I have emailed Dave with the RS2 and am hoping to get together with you and him and ?? somwhere in downtown Calgary.
                  Dave F.
                  • Jonas_R
                    • 3780
                    • Country: Denmark
                    I'm running the Forge DV 006 and i'm happy with it.
                    Sleeper S2 Avant +450
                    A6 Avant 2.7t Stage 3
                    Audi S2 Coupe RS2'ed
                    • EspenW
                      • Apr 2007
                      • 1534
                      • Country: Norway
                      From what I've seen, brand new 710N's last less than a few months when running 1.6bar, so with 1.9bar+, I'd go for a Forge 007 or similar.
                      Make sure your ignition system is working properly, with the 11mm rotor and change to the metal dizzy gear of it still got the plastic one. Ignition firing off at the wrong instant has killed numerous of these engines.
                      1994 80E Avant
                      1986 2L Golf 2 on Alcohol
                      • archiboy24
                        • Sep 2003
                        • 286
                        Thanks Dave. I think I'll go with the H. I'm pretty sure I saw the article you mentioned.
                        Ironically, it looks like I'll be in Vancouver next weekend. If not, I'll be sure to join you and Dave and a few others. Are you in Calgary often?
                        Ben
                        Ben
                        Calgary, Alberta
                        Canada
                        • archiboy24
                          • Sep 2003
                          • 286
                          Thanks. Sounds like good advice. If I'm not mistaken, I believe the proper rotor for the 3B is 10mm. Already have the brass dizzy gear.
                          Ben
                          Calgary, Alberta
                          Canada
                          • dkw_dude
                            • 555
                            • Country: Norway
                            Remember to get the right spring for the 007. With that boost I would use the red (spring ranges from green yellow blue red, low to high boost. At least when I got my 007 a few years ago).
                            Leif-Helge
                            -91 S2 VEMS and Comp Turbo
                            -12 B** 530XD Touring "S2 parts transporter, and daily driver"
                            • K Simmonds
                              • Dec 2007
                              • 7627
                              I've gone for one of these for my 3B RS2+ project. Got it for south of a £100 from the bay of thieves, they are more like £300 full list price. Just visually examining it's obviously far superior quality than say a Forge or Bailey and I have no doubt it will work just as sweet as it looks. Fully adjustable recirc/atmos dump and adjustable for attack speed as well. Won't be long now until it's on the car as my project has been progressing nicely of late.
                              1990 B3 2.0 80 quattro.
                              1992 C4 2.8 Avant quattro
                              1994 MTM RS2.
                              1998 B5 TDI quattro Sport.
                              2000 B5 TQS.
