Would you keep aux rad????
  • T2Andy
    • 1903
    @RUSTY that sounds a great idea i will be ready for both soon me thinks
    • trackslag
      Account Disabled
      • Sep 2009
      • 171
      Originally posted by Rusty
      I have removed the AC and fitted an RS2 pump and belt. I'm going to get a price on some alloy main and aux rads soon.
      let me know sooner the better when i drove my car up to have roll cage fitted it got really hot and cracked the plastic top on the rad so i will be needing a new main rad soon and poss a fan but cant check that untill car back on drive way. just hope it gets me home
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        #48
        For an out and out track car ditch the aux rad and fit a alloy main rad, like the one from Ron Davis.
        SS
        • trackslag
          Account Disabled
          • Sep 2009
          • 171
          the poll results are so close that im no better off than I was two days ago 17 say yes 18 say no, need more............................. this seems to be a Marmite question? LOVE IT OR HATE IT
            once you've had to do a few more jobs on your car you'll realise its a major PITA and bin it
            • s2driveruk
              • 12696
              ditch it...
              The worst that happens retaining just the stock main rad is that the fan kicks in more frequently during the summer months. Had mine out for year with no real downside. Temps are stable regardless of road or track.
              If the cooling system is in good health then no reason to worry and having ability to run the fan (hardwire as per Rusty) or retain the a/c if you want to keep it on the car (never been convinced there is that much weight to recover - say 15kgs for pump and pipes plus evap)
              Totally agree if you live somewhere with a proper summer but elsewhere you'll be fine
              Another vote for Water Wetter. Used it a few years ago and car ran a few degrees cooler which was a boon considering the car spent hours queuing in and out of two grand prix's in europe. Actually descaled the coolant circuit nicely too so would use it for a few months, then drain and flush and then refill!
              David
              1992 3b S2 Coupe
              • trackslag
                Account Disabled
                • Sep 2009
                • 171
                i live near sunny Southampton so dont need to worry to much about the out temp getting hight LOL
                  On water wetter i've considered it, is it safe to use with the G12+ then/
                  • T2Andy
                    • 1903
                    I used REDLINE ww for over 12 months mixed with g12 with no adverse affects
                    • EspenW
                      • Apr 2007
                      • 1534
                      • Country: Norway
                      #55
                      If I remember correctly, Redline recommends against using Water Wetter with G12/ G12+
                      1994 80E Avant
                      1986 2L Golf 2 on Alcohol
                      • Colesy
                        • Feb 2009
                        • 2981
                        I'm watching this thread quite closely also as I removed my Aux Rad a month or so ago after it sprang a leak.
                        So far it has been fine without it although I have noticed in London traffic that the water temp is getting a quite a bit higher (100ish) than it used to and that's in autumn.
                        So thinking that for the summer in London traffic I may have to invest in a new one, or maybe not?!
                          Look at my thing for wiring a switch to the fan, keeps things a little cooler than not having it. Looking at ally rads with trackslag and also new, more efficient fans.
                          • Key Walshe
                            • Feb 2007
                            • 422
                            #58
                            I've ran mine for nearly 2.5yrs now without the aux rad, it sprang a leak in autumn so left it til spring. After reading up on its pros & cons decided to try it over summer without and its been fine, even on the hottest days.
                            It's sat in hours worth of slow moving traffic mid-summer and never goes past 92C, and even after spirited blasts it sits at 90. The addition of silicone hoses (Roose) also helped a little further, better flow maybe?
                            This is on a Nothelle spec car too with extras, so though not highly tuned its up on standard power figures.
                            Audi 80 S2 Nothelle N300 Avant, 1993, Amethyst Pearl VW/Audi Car Magazine article about this very car
                            Audi A6 Avant 2.5 TDi, 1995, Arctic Silver (now sold)
                            BMW E36 325i Coupe, 1993, Diamond Black (now sold)
                            VW Polo 1.0L 6N, 1998, Red (the missus' car)
                            Aprilia Rs250 motorbike, 1998, Black (the weekend toy)
                            • 90/90qs
                              • Jun 2006
                              • 244
                              Originally posted by trackslag
                              would removing the thermostat help to keep temp down as water can flow faster? not to worried about slow warm up as just wont boot it untill temps up abit. dose anyone have a link for the allysport rad? i neede a new main rad and can only find ally ones from 034 at the mo
                              I read (but never verified) that 'out of nominal' oil temps can be harmful. Something like (but maybe not exactly) cold oil has a tendency to suck or condense water, so oil passages may begin to corrode or restrict flow from sludge; plus water does not help for lubrication. - Oil temps that were too high became semi corrosive and could harm lubricated surfaces over time.
                              http://s260.photobucket.com/albums/ii11/minipitt1/
                              • OKP
                                • Apr 2009
                                • 25
                                • Home: United Kingdom
                                #60
                                Have you seen the price of these things? When mine fails i won't be replacing it.
                                Its made with bits of real S2, so you know its good...
