Would you keep aux rad????
Removing the thermostat will cause the flow to become too fast, decreasing heat transfer at the radiator, thus increasing temps.would removing the thermostat help to keep temp down as water can flow faster? not to worried about slow warm up as just wont boot it untill temps up abit. dose anyone have a link for the allysport rad? i neede a new main rad and can only find ally ones from 034 at the mo1995 RS2 on Alcohol (6.8sec 100-200km/h)
1994 80E Avant
1986 2L Golf 2 on AlcoholComment
If your going for light weight then the aircon would have be one of the first things on my list to get shot of, it's weight at the front and thats where it least needed. Also getting rid of the aircon rad vastly improves the efficiency of the main rad meaning the aux rad is redundant, in our clime's anyway.
If you cambelt needs changing soon then no harm in going for the RS2 pump and belt as they can only do good. However if your belt is relativity new then I wouldn't both ripping it all apart just to that job. I'd wait till it was cambelt change time, every 50k or 5 years is my general rule; But if your having the bottom end apart to rods ect, which I suspect you are, then you may as well do it then as well as a cam belt change. Next time mines apart is going to get the RS2 pump and belt.1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.Comment
keep it... it always can help the main rad. Unless you got an aftermarket and bigger radiator with a nice fan behind it. cheers!- Looking for a S2
sigpicComment
It was 36 deg c the other day and i gave the S2 a fair flogging, oil temp got to 100 after about 20 minutes of caining, water temp sat at 92-94. I have no aux rad.Everything should be made as simple as possible, but not simpler.--:Albert EinsteinComment
I have kept mine on and thank God...
Sitting in city traffic in the midwestern parts of the States in the dead of Summer with the AC going full blast will tax the cooling system to the ultimate!!
Without the aux. radiator my motor would have been toast a long time ago.
I'm changing my radiator now because of the typical BEHR failure...cracked upper left side.
Can I use a UR-Quattro radiator in my CQ? Were they all metal?
It actually doesn't in moving situations as the rad is in parallel it actually in my opinion decreases the cooling potential as it's not as effective as the main rad due to the smaller surface area.Comment
RS2 water pump fitting
Did I read somewhere the RS2 water pump fitting is 1 tooth out?sigpic
Other cars:VW Transporter T5 4motion, 'S3 sportbackComment
I removed my aux rad a few years back, no issues, it does run cooler at the track now the AC is gone though
