Paul,
today i got the chance to have a gander at the vacume hoses around the ECU, the hissing noise does not sound like its coming from anywhere near the ECU! I did do the suck test on the vacume pipe on the ecu and in not 100% sure but pretty sure it was holding a vacume, the noise seems to be coming from higher up, if your sat in the passanger seat of the car it sounds like its coming from the rear left hand corner of the glovebox, so i had a look and theres a brass "looking" valve of some description that seems to have a vacume outlet/inlet with no pipe on it? it had several other pipes coming out of it, but i couldnt see a stray pipe to plug into it, what is this valve, and what should be plugged into it, i susspect that what ever and where ever this pipe is, thats whats making the hissing noise (the valve thing kinda looked a bit like a N75 valve)
