boost / hiss noise (RS2 spec coupe)
  • avants2turbo
    • Feb 2008
    • 1287
    right, hissing/leak located, it was the hard black vac line that should go to the check valve, couldnt get it back into the check valve, so its plugged straight into the recirc valve (is that going to cause a problem?) anyhow, hissing/leak rectified, i did take it around the block, but it was end of school run/begining of rush hour time, am going to take it for a blast in a bit, and report back
    • Kieron20V
      • Mar 2008
      • 1505
      #32
      Good luck Keith, Cheers for last night.
      1994 URS4 Avant RS2+
      • gavs20v
        • Sep 2004
        • 3057
        Did he buy you flowers after?:corey:
        S2 Cabriolet.........
        • Kieron20V
          • Mar 2008
          • 1505
          #34
          Haha, no he threw me a towel, called me a taxi and kicked me out.......
          • gavs20v
            • Sep 2004
            • 3057
            he's such a player....tart
              If the line goes to the recirc valve without going through the check valve then the recirc valve will see boost which is not good.
              • avants2turbo
                • Feb 2008
                • 1287
                Whats it gona do? Anyone know if this s2 has had a clutch anytime recently?
                • avants2turbo
                  • Feb 2008
                  • 1287
                  Moi? No.....
                  • A80Avant
                    • Sep 2005
                    • 10873
                    • Country: Greece
                    #39
                    so this turned out to be an air leak then... Let us know where the vaccum on the guage stays now that you have fixed it. Is it lower or higher than before?
                    good find avants2!
                    • avants2turbo
                      • Feb 2008
                      • 1287
                      on idle its -0.6bar and it still only boosts to 1.1/2 bar in 4th
                      • A80Avant
                        • Sep 2005
                        • 10873
                        • Country: Greece
                        #41
                        oh ok, so still work to do!
                          Originally posted by avants2turbo
                          Whats it gona do?
                          Well dont know exactly but the recirc valve is vacuum operated, not designed for pressure, so might possibly break. Thats why I just plugged plugged the line. Its a mystery how this got to be like this eh?
                          • quattro20v
                            • Jul 2007
                            • 173
                            My next step is to check the backpressure of the exhaust from the downpipe niple, have an extra boost gauge but have to buy some hose to make the connection to the downpipe for a few test runs.:mischeif:
                            Don't know but my cats could be bad.
                            Now quattro less, my urs4 stolen 13.8
                            • avants2turbo
                              • Feb 2008
                              • 1287
                              mine cant, i dont have any cats, and only 1 small box
                              • stevieyid
                                • Apr 2005
                                • 2251
                                Keith its not had a clutch in the last 5 years as far as i know. I have not had it replaced and i dont think jonnyk did in his ownership. Im not sure previously to this.
