not possible (i think) because i had the same problem with my RS2 fuel pump and now with my 044 bosch motorsport pump...
i used both with 2 different sets of new injectors (RS2 injectors and 440/3bar greens)...always the same
all the ignition parts are new too,since the battery,spark plugs/wires,distributor rotor, knock sensors....
and the cambelt was installed perfectly in complete original position.
i am using the 7A exhaust cam,but i think that it can not be the problem
really i dont know wich point to check....
only i have to check the fuses,relays,wires or the many sensors
