some tests with bad results ¡¡
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    #76
    Originally posted by Jon441cc
    Bingo, Fuel pump may be an idea
    not possible (i think) because i had the same problem with my RS2 fuel pump and now with my 044 bosch motorsport pump...
    i used both with 2 different sets of new injectors (RS2 injectors and 440/3bar greens)...always the same
    all the ignition parts are new too,since the battery,spark plugs/wires,distributor rotor, knock sensors....
    and the cambelt was installed perfectly in complete original position.
    i am using the 7A exhaust cam,but i think that it can not be the problem
    really i dont know wich point to check....
    only i have to check the fuses,relays,wires or the many sensors
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      #77
      Originally posted by vertigone
      Hello Friend !
      What about your fuel system ? injectors and fuel pump ?
      read my last answer,i think that it is impossible
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        #78
        here the video of my boost cut....
        i was with my cousing and his girlfriend
        • Costash
          • 878
          • Home: Romania Current: United Kingdom
          #79
          Sounds to me from first movie like a misfire.
          • A80Avant
            • 10873
            • Country: Greece
            #80
            you do know that you have the gauge holders upside down...?
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              #81
              yes i know it,
              they works perfectly and looks different
              • Rocco
                • Aug 2007
                • 6393
                • Country: Spain
                #82
                and what can be??
                the single coil???
                • M_GORDON
                  • Oct 2008
                  • 1295
                  • Home: Isle of Man Current: Vatican City State
                  #83
                  Originally posted by Rocco
                  and what can be??
                  the single coil???
                  Tom, who is the single coil? "Bobina de alta"?
                  photobucket SUCKS
                  • Rocco
                    • Aug 2007
                    • 6393
                    • Country: Spain
                    #84
                    STILL desesperated with my 3B
                    today i was testing another 3B MAF...with the same bad results about boost cut to 0.4bar
                    and this one added a very very rich AFR values...very bad¡¡¡ around 9.8 and 10.2 with WOT¡¡
                    dont know why.... anyway the same boost cut appears after 4 seconds with WOT....
                    things done and tested:
                    2 different fuel pumps
                    2 differents softwares
                    2 differents new turbos
                    2 different MAFs
                    2 differents injectors
                    2 differents N75 valves
                    boot leak test
                    2 differents octanage fuel 98 and 103
                    all the ignition parts are complete NEW¡¡ except the Ignition COIL.... but i bet for my problems did not came from the ignition..because it runs very fine and like a missile¡ but it does boost cut all the times. droping always to wastegate pressure.
                    i am sad
                    does someone had something similar like this???
                    i am thinking in unplug the N75 connector and insert a manual valve between N75 and wastegate hose...and see what happens... maybe with pressures under 1.3bar (for example) this boost cut does not appears...
                    what can i do friends??? renew every sensors in the engine?'
                    • jorge s2
                      • Feb 2009
                      • 226
                      • Home: Portugal Current: Spain
                      #85
                      audi s2 aby red 1993 powreded by prj
                      • Costash
                        • 878
                        #86
                        Try other ignition coil if you have the chance.
                        • Rocco
                          • Aug 2007
                          • 6393
                          • Country: Spain
                          #87
                          tried today another used ignition Coil with the same boost cut
                          and we tried too another Motronic with my software and 200kpa sensor..... boosting less,but still having the same problem droping the boost to 0.4bar very fast
                          Vagcom 0 errors.....
                          all wirings and valves pluged correctly.....
                          i am very sad i wish to know what happen¡¡
                          • tajgreidotu
                            • May 2008
                            • 324
                            • Country: Spain
                            #88
                            knock sensors?
                            • T2Andy
                              • 1903
                              I had same problems ,i changed my ecu and chips ,maybe you need a new map sensor
                              • Rocco
                                • Aug 2007
                                • 6393
                                • Country: Spain
                                #90
                                Originally posted by tajgreidotu
                                knock sensors?
                                knock sensors are complete new¡
