Main Bearings.
This is a sticky topic.
  • terrybullwon
    • Mar 2006
    • 8782
    Originally posted by Rezlo
    Can you guys tell where you buy these bearings from? preferably online as I need to order a set.
    Ebay.de or Aelred off this forum might help
    Chef
      Aelred is your man
      • QuattroFever
        • May 2006
        • 1360
        combined thrust washers???
        Do these engines use thrust washers along the crank, and in how many places???
        Volcano ABY coupe
        Ant
        • lind4hl
          • Jul 2008
          • 2465
          in 1 place (middle) if we are talking about the same things..
            DO NOT USE COMBINED THRUST WASHERS!
            • QuattroFever
              • May 2006
              • 1360
              do they need thrust washers as standard with standard bearings?
              Volcano ABY coupe
              Ant
              • V6quattro
                • Sep 2008
                • 949
                Any one know if this is the right set of main's for a high power s2?
                http://cgi.ebay.de/Hauptlager-inkl-A...72882408250588
                Tanks,
                Roy
                • Gringo
                  • Jan 2005
                  • 139
                  DO NOT FLUSH TOILET!
                  Sorry, couldn`t help my self
                  On a more serious note;
                  Do not use combined thrust washer with highperformance clutch on a daily driver.
                  Use whatever you want on fullblown race car engine. You`re going to overhaul it once a year, or at least every other year, so whatever you use will be just fine.
                  Now you see me, now you don`t
                  80quattro.com
                  • bikerjim
                    • Feb 2008
                    • 1028
                    Im glad this came up.
                    Im in need of some big end and main bearings for the 1.8t 20v engine i am building. I have herd sputter bearings are available but what do you guys think about brands of bearings? I have herd of KS bearings and since this thread Glyco bearings. Whats the verdict and where can i get them from?
                    • V6quattro
                      • Sep 2008
                      • 949
                      Tanks,
                      Roy
                      Today i received the bearings. Thy look very good!
                      Roy
                        #41
                        Reputable specialists should be able to source bearings from KS or Glyco - they are both well known brands with trusted reputation and many factory fitments. I posted excerpts from the KS catalog here before so you can source part numbers and double check oversize specs and sputter variants.
                        • Thuppu
                          • 4115
                          Which ones would you prefer, KOLBENSCHMIDT or GLYCO?
                          • Pirvu Eugen
                            • Apr 2007
                            • 1978
                            • Country: Romania
                            #43
                            The oem ones..are Glyco.
                            • Thuppu
                              • 4115
                              Ok, thanks. I think I go with the same ones that Roy in post #40.
                              • V6quattro
                                • Sep 2008
                                • 949
                                The are nice OE bearings. Installed them recently.
