Volvo K24 turbo in audi application.
  • andy10v
    replied
    Some more part numbers and pictures
    Porsche 944 220bhp k26/6
    Porsche and volvo
    Porshce tag
    Porsche Hotside
    Both Units (volvo left)
    Both hotsides (volvo left)
    Porsche hotside loosely on volvo unit
  • andy10v
    replied
    Originally posted by fridtjov-audirs2
    Does anyone have one for sale???
    I got mine on a volvo forum, signed up to a few and just posted up an introduction and a wanted, got one pretty quick.
  • fridtjov-audirs2
    replied
  • Ruffiano
    replied
    Here is a vid from the Dyno Day in April
    This is "QuattroWorld Utah Dyno Day April 2011." by Nick Simpson on Vimeo, the home for high quality videos and the people who love them.
  • javispa
    replied
    Originally posted by porkkis
    I'm a bit confused about the numbers you guys talk here. This turbo will not make more top end power than a RS2 unit. Period.
    I can offer 3B chipset for K24-7400. I have mapped such car. I did like the turbo.
    Hi Porkkis, which injectors, fuel pressure regulator, and other bits (like exhaust manifold, intercooler, etc), were used in the 3B you mapped? Which torque numbers did you get?
    I might be interested.
    Thanks.
    Cheers.
  • prj
    replied
    No idea what power level I was running...
    It felt pretty quick though, even in my big heavy car.
    Injectors seem to be 510cc, not 550cc though...
    Anyway, perhaps should continue the discussion elsewhere, as this has nothing to do with the Volvo turbo.
    replied
    Bad luck Dmitri but it does seem like re-used bolts contributed to this failure - thats my opinion from long distance without seeing anything of course.
    @Ross - these are same injectors that shipped to Sonic, and will come to me for some playtime - Dmitri proved the latency numbers to be close to theory on his car. I will take a second set of measurements for comparison. It looks like these are good to go for you and others as you can see from the IDC on hefty power levels for K26/27 sized installations. This must be in 430-450bhp territory.
  • prj
    replied
    Originally posted by Ross
    1.55bar to near enough 7k rpm as well :mischeif:
    What injectors are those for 78% duty at that power level?
    510cc ev14, I have stock head, stock ic on this car.
  • Billman
    replied
    @Prj
    do you have a log of a big turbo engine you mapped? Log from the final map.
    How log do you need on the dyno to map an engine?
  • Ross
    replied
  • prj
    replied
    It's big end bearing knock and oil pressure is gone.
    I did not run it like that for more than 10 seconds.
    It's of course running, so I don't think the block is gone.
    Will see when we open it this weekend.
  • Thuppu
    replied
    Originally posted by prj
    ...and I have a set of H-Rods that'll get put in...
    So this was a good thing after all. The rods don't need to collect dust on the shelf anymore.
    What kind of noise did the engine keep? Do it still run, or is it jammed?
  • prj
    replied
    That sucks, sorry to hear that... just be glad you didn't put a rod through the block
    Still, looks like it's making you peak boost around 3900, not bad for an old-skool 420hp turbo?
    It's not bad at all. Pull is in 3rd gear
  • Ross
    replied
  • prj
    replied
    Originally posted by andy10v
    That is sad to hear, hope you get a relatively straightforward fix.
    What is the plan for the engine then? Or will you decide when you get it apart?
    First pull apart and see how much damage is done.
    Probably "new" crank, new shells, and I have a set of H-Rods that'll get put in...
    This is if the block is OK.
