Time for me to ask for help.
My car seems to run lean (with different chipsets) and I am slowly running out of things to try to improve the situation.
AFR's under boost (1.2-1.3 bar) 12.9-13.4, when starting to accelerate 15.8-15.9.
This chipset should run closer to 11.5-12, not 13. At 2900 rpm in that graph is knock, that is why motronic pulls some boost. Others run this chipset at higher boost levels without issues.
This is a generic chipset, I removed my modifications. Ambient temp was about 5 degrees celsius.
Second gear pull:
Background info:
UrS6 AAN, stock injectors, stock turbo, Motronic.
Engine rebuilt two months ago, brand new MAF, RS2 exhaust manifold.
Things I have tried so far:
1. Different ECU software, that I have seen run richer on other cars.
2. I have absolutely no boost leaks. System is completely pressure proof up to 2 bar starting the MAF-Turbo hose.
3. Different FPR
4. Different MAF
5. Injectors cleaned
6. Fuel filter changed
Today I will temporarily separate the breather system from the intake and also measure my fuel pressure (maybe my pump is going out), then also try totally stock ECU software and measure AFR under boost (it would be helpful if someone could give AFR's with stock software).
If this does not help, then I am out of ideas.
Second gear pull:
Background info:
3. Different FPR
4. Different MAF
