Tis indeed a peg in the flywheel that G4 detects. Theres another peg for G28 also...
Non-starting
has any one got pictures or diagrams where these are? how easy is it to tell if there is something wrong?.....still raining so havent checked dizzy yet but then i have a suspision it's not that as there is no injector pulse either would the dizzy create that?Comment
The workshop manuals say the inlet manifold must be removed but it can be done without doing that, but you'll have a lot less skin on your hands,
take all the leads off, then wriggle the cap off then get at the bolt at the dizzy base, but if your anti tamper bracket is still on (a plate rivited over the bolt) it will be a lot harder,
saying that, removing the manifold is pretty straight forward. just leave everything attatached to it though and tie it to the underside of the bonnet with out the way.
i'd take the cam cover also and get out the remnants of the old gear, and change the oil
martinComment
Hah! You RHD guys must have plenty of space there, not even tight!
You can also buy an original dizzy gear if you wish. It's from SPQ engine code KW. No idea in replacing the whole dizzy because of the gear. (actually I think few of you here have some new part fetish, replace replace replace, even if not necessary.. clueless)
When installing, turn the engine to the 0-mark and the allign the rotor so that it points to the groove on dizzy base.
And when your cam belt renewal time comes, replace the chain between the cams. It loosens over time and adds vibrations to the inlet cam that drives the dizzy, this causes the gears to break.-Comment
Yep gear has sheared BTDT, complete new dizzy is about £100 from the dealers, includes new rotor arm and cap. I had this happen to me. Take the Inlet manifold off, as that tamper proof tap will be impossible to get off otherwise.sigpic
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nmComment
