Drain to sump
  • Jeffer
    • 2057
    yes leave it permanently open. I never had problems with this.
    RS2 Black - stock 315 HP
    RS2 RS blau - stock 315 HP
    Sport Quattro - 1005 HP
    High Octane website
    • A80Avant
      • 10873
      • Country: Greece
      can you tell me if the part number is the correct before i order it? because on the I5 the thread is M26x15 and the fumoto equivalent to that is the one i mentioned above,
      but the store gives a different thread for the audi rs2!!!!
      • Jeffer
        • 2057
        I bought that thing 7 yrs ago, so i cannot remember the partnr. sorry
        High Octane website
        • A80Avant
          • 10873
          • Country: Greece
          I see. Make jp can help!
            Be careful using Fumoto valves as a return, they can break ask S2avant on this one
            • terrybullwon
              • Mar 2006
              • 8782
              Originally posted by A80Avant
              what is the equivalent to the M26x1.5 of the OEM sump plug in US measures? is it 1/4?
              M26 is not 1/4"
              You can get M26 to -12AN though
              Indeed James's broke also
              Chef
              • Jeffer
                • 2057
                wich one did you use? the one with internal thread or the hose adapter on it? The one i use with the hose adapter had by the look of it enough flesh in it to hold the hose and not break. 4 years of service proved that it worked...
                High Octane website
                • terrybullwon
                  • Mar 2006
                  • 8782
                  Another James so i cant comment but i know it was pretty old
                  I had on mine a M26 to -12An fitting which when to tank return
                  Chef
                  • A80Avant
                    • 10873
                    • Country: Greece
                    #24
                    Well the thread is 20 thick so with a 90 bend and a flexing hose from the catch tank, why should I break?
                      Avez vous un link, monsieur Terry?
                      • terrybullwon
                        • Mar 2006
                        • 8782
                        No sorry, call earls it's about £20 Inc vat iirc
                        Chef
                        • A80Avant
                          • 10873
                          • Country: Greece
                          #27
                          I have just been told that the AAT engine comes with a dyno plug that has an adaptor for a return hose. I don't have etka at work. Anyone has a part number, or can confirm?
                          • GT500
                            • Jun 2006
                            • 2181
                            Just looked, its m14..
                            Rob..
                            87 UR 20v ABY
                            97 S6 Avant
                              Yes it does, I posted a thread about it a while back but the sump plug is a different size to the S2
                              I did a thread about plug returns ( cant be bothered to search ) upshot I have a return pipe that fits in the sump, I'll find it and put it up for sale
                              • GT500
                                • Jun 2006
                                • 2181
                                RS one is m26!
                                Rob..
                                87 UR 20v ABY
                                97 S6 Avant
