Catastrophic engine failure
Have the turbo inspected for eventual hits of piston, valve debrees.
Let the injectors and FPR checked out also (maybe you detonated because of a clogged injector).Go Holset or Go RS4Comment
You can check the injectors pretty easily by pulling the rail out and running the onboard diagnostics. They spray in firing order. It's not quantitative unless you rig up a 1348/2 or similar, but it's pretty easy to spot an underperforming injector while still on the car.Comment
I hope you didn't wash the engine bay before this
look at these pictures of a recent engine blow in Spain. the engine comes from a Audi RS2,original,without boost too much.
the guy said that that made WOT in 6th gear from to 120km/h to 160km/k and then "BUMPPP"
LWB Audi Sport Quattro projectComment
Agree absolutely, but it's much more expensive and time-consuming. The diagnostic trick WILL spot a completely dead injector, costs almost nothing to do and takes minutes.
It's all too easy to start swapping bits in the hope of randomly hitting the defective component.Comment
Erm - if they're not on the engine then you don't have to factor in the cost of removing and refitting them, do you? Completely different situation - I'm talking about a quick check with them still on the car.
5% is within manufacturing tolerance and - unless someone's done something really wild with the ECU - will easily be accomodated by ECU knock control.Comment
I removed, installed them myself, it is a 30' job.....just it's up to you/him.Erm - if they're not on the engine then you don't have to factor in the cost of removing and refitting them, do you? Completely different situation - I'm talking about a quick check with them still on the car.
I wish that this knock control is as good as we believe....but many engines got destroyed and will....Go Holset or Go RS4Comment
