Virtual Dyno Room
This is a sticky topic.
4th gear pull. Testweight was 3550lbs (with driver)
Turbo/injectors/FPR/fuel pump/DV/MBC/software/some silicone hoses/catback is not stock. The rest of the setup is stock ADU. Ethanol fuel. Peak boost is 2.25bar:
Last edited by EspenW; 5 November 2011, 21:52.1995 RS2 on Alcohol (6.8sec 100-200km/h)
1994 80E Avant
1986 2L Golf 2 on AlcoholComment
Here is another pull with somewhat more torque. Peak boost is 2.25bar and tapers to approx 1.7bar at 7200rpm. When the weather turns cold I will turn up the peak boost to 2.4bar in order to get my 100-200 time into the 6 second bracket (no shift 4th gear pull).
Testweight for this pull was 3505lbs/1590kg (with driver)
Last edited by EspenW; 5 November 2011, 00:11.1995 RS2 on Alcohol (6.8sec 100-200km/h)
1994 80E Avant
Not sure about the dip on the RS4, could be timing pull on that run, or it could be cams kicking in at higher rpm. It was not as pronounced on the 3rd gear pulls. Timing logs revealed nothing wrong, and in-gear timed runs were pretty much spot on with tests of the same car in the magazine "Sport Auto", so it seemed very healthy.
Numbers are from logs.1995 RS2 on Alcohol (6.8sec 100-200km/h)
1994 80E Avant
