Originally posted by A80Avant
View Post
Virtual Dyno Room
This is a sticky topic.
Here are a couple of other results from old logs...
Friend's RS2, 3071R stock motor, 95oct. fuel, peaking at 1.7bar and holding 1.55bar at the redline. Very safe tuning.
My car with the holset HX40Super, experimental tune, so possibly could have more timing, but 1.4bar 3d gear, vs current setup
you can tell now why i didnt like the holset.. haha!
Billman will respond any minute now
Originally posted by EspenW View PostNot sure about the dip on the RS4, could be timing pull on that run, or it could be cams kicking in at higher rpm. It was not as pronounced on the 3rd gear pulls. Timing logs revealed nothing wrong, and in-gear timed runs were pretty much spot on with tests of the same car in the magazine "Sport Auto", so it seemed very healthy.
Numbers are from logs.
I need to do some pulls in mine ... mine is "only" rated at 440 PS
Chip is from SKN...
I need to remap it myself, it is running baby boost atm.
It would be interesting to see your log compared to an equivalent power I5 (like mine :mischeif - get those logs Dmitri.. great looking RS4 btw. I've committed to the RS2 now but maybe one day... I'll have one of each!
@Vas - you have PM, I think a log comparison is in order. I'd like to see my car vs a GT3071 set-up. I want to get some logging set up on mine too, I'll get mine on the rollers at MRC with Andy when he has his ready but that is probably not going to be for another month at best.AUDI - saving Dad's from minivans since 1994
Originally posted by A80Avant View PostHere are a couple of other results from old logs...
Go Holset or Go RS4
331 is not far off from 286 and some variables may come into play. However my point was how can a few degrees of timing may make such a difference when we are talking about a comparison between a smaller and a much larger turbo! And of course how.much head porting can affect these engines.
sent using Android
5-6 deg timing in the correct place will be 150-200 rpm spool.
If you are running too little the car will be laggy, slow and generally feel like ****
Originally posted by Ross View PostIt would be interesting to see your log compared to an equivalent power I5 (like mine :mischeif - get those logs Dmitri.. great looking RS4 btw. I've committed to the RS2 now but maybe one day... I'll have one of each!
sent using Android
Originally posted by prj View Post5-6 deg timing in the correct place will be 150-200 rpm spool.
sent using Android
Here is another interesting one: RS2 with Hohenester Stage 5 setup. Ported head, cams, forged internals, special Hohenester spec K26/27 turbo, full 3" exhaust, etc. 1.6bar peak boost on 98 octane. It is rated by Hohenester at 400ps and 560nm at the crank.
Note: this is a 3rd gear pull. 4th gear pull gives better load on the engine, and I always see better torque figures on I5s with larger than RS2 turbo when testing in 4th vs 3rd. Peak power is usually very similar, probably due to slightly higher rolling resistance at the max hp speed in 4th vs. 3rd. On smaller turboed cars and K04 2.7TTs, etc, there is very little difference between 3rd and 4th, since these spool very quickly even in lower gears.
Last edited by EspenW; 4 November 2011, 10:59.1995 RS2 on Alcohol (6.8sec 100-200km/h)
1994 80E Avant
1986 2L Golf 2 on Alcohol
