Virtual Dyno Room
This is a sticky topic.
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    #91
    since E85 is more readily available, i would go that route as well, or even a switchable map if needed.
    How is the rest of the rs2 Espen? engine wise, have you done anything to it?
    • EspenW
      • Apr 2007
      • 1534
      • Country: Norway
      #92
      On my RS2, the non-stock ADU components are the following: turbo, software, injectors, 044 pump, adjustable FPR, Forge DV, MBC, a few silicone hoses and a Milltek catback. Aux rad is removed.
      1994 80E Avant
      1986 2L Golf 2 on Alcohol
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        #93
        good stuff
          #94
          Espen,
          What's a LOBA Package for an RS4 ?
          Just idly curious.
          Thanks.
            Loba motorsport they are all over audisrs with products such as turbos fuel pumps clutches
              #96
              In German and and no B4 / C4 stuff, no worries though.
              Thanks for reply.
                Check Audisrs or speak to Quattronutter as he hs bought and installed various S4 / RS4 loba packages for his and customer cars
                • EspenW
                  • Apr 2007
                  • 1534
                  • Country: Norway
                  #98
                  Here is another and better graph for the MTM RS4. This is 3rd gear instead of 4th, smoother curve and somewhat better numbers:
                  1994 80E Avant
                  • A80Avant
                    • Sep 2005
                    • 10873
                    • Country: Greece
                    #99
                    This is the best run i could find on my 3076R
                    apparently at some point i had realised i had some boost leak due to a ruptured vaccum hose, and i guess this is the only run i can find logged that boost was able to be kept this high.
                    its a run of 2bar overboost coming in quite fast and 1.96bar till 6000ish rpm where the run ends. I was running 225/40/18 tyres then and 245/35/18 now.
                    I can notice an almost identical spool on the 2 setups, but i must say that the spool on the current setup will improve as the WGFV DC is getting reduced drastically in order to avoid a spike over 1.4bar.
                    More fun after next weekend and the mapping session!
                    • A80Avant
                      • Sep 2005
                      • 10873
                      • Country: Greece
                      #100
                      and here is the comparison to Ross's K27/26
                      • EspenW
                        • Apr 2007
                        • 1534
                        • Country: Norway
                        #101
                        Nice curves!
                        Do some tests in 4th gear as well. If no private track is available, one can do a pull up to 5500rpm (still under 100mph) in 4th to get the fat part of the torque curve. I guarantee an improvement vs the 3rd gear pulls.
                        1994 80E Avant
                        • A80Avant
                          • Sep 2005
                          • 10873
                          • Country: Greece
                          #102
                          ill try and do one or 2 this week, as im getting on the dyno on saturday for a session there
                          • EspenW
                            • Apr 2007
                            • 1534
                            • Country: Norway
                            #103
                            Sweet. Will be cool to compare the VDR results to the dyno numbers. What dyno are you going to?
                            1994 80E Avant
                            • A80Avant
                              • Sep 2005
                              • 10873
                              • Country: Greece
                              #104
                              i dont know the make yet, but a load based dyno so we can do the mapping properly
                              • EspenW
                                • Apr 2007
                                • 1534
                                • Country: Norway
                                #105
                                What company/tuner?
                                1994 80E Avant
