Turbo removal
  • Simons
    • Jul 2007
    • 530
    • Country: Spain
    Hi, I removed the downpipe bending a 15mm spanner, and it was easy
    I did it in two steps
    First 90ยบ
    It isn't enought clearance to unscrew the bolt
    More hot and the second step
    And the result was this
    • Dobby84
      • Feb 2011
      • 1169
      Cheers for that, I kinda assumed that was the best way of doing it. I was just checking that there wasnt any crafty way of doing it. The 3 sprung bolts on the end of the downpipe are pretty corroded and may not handle being undone.
      • Dobby84
        • Feb 2011
        • 1169
        Yeah thats what I have done, Unbolted the sprung nuts and bolts, this allowed me to wiggle it about a bit and get better access.
        The Turbo is now off and im cleaning all the pipes ready for my shiny new one. :-)
        • Simons
          • Jul 2007
          • 530
          • Country: Spain
          and how will you tighten the downpipe, the "bad" nut
          • Dobby84
            • Feb 2011
            • 1169
            Well Ill put it back together the way I took it apart, Ive got some s-spanners now that do the job nicely.
              Get a 3" DP, you can do it in a few minutes with a spanner and a 1/4 drive socket set
              • Dobby84
                • Feb 2011
                • 1169
                Where would I get one from and how much are they? Running on a budget at the mo so doing things bit by bit.
                • Phil Payne
                  • Jul 2009
                  • 328
                  Originally posted by Dobby84
                  Hi guys, Ive been struggling this weekend to get my broken turbo off, I have basically stripped everything back so I only need to unbolt it from the exhaust. Any tips or methods ho to do this as from what I can see its gonna be a nightmare to get to the nuts etc.
                  If someone has any advice then please let me know, I havent got my skin on my nuckles left. lol
                  I use a FACOM semi-deep socket, a universal joint, a long extension and gimbal-head ratchet from the rear of the engine bay.
                    Error404 is the king of this nut, ask him how to do it
                    • Dobby84
                      • Feb 2011
                      • 1169
                      Well now I have it out and know what im doing fingers crossed the new one goes in with a bit less effort.
                      • madpugger
                        • Sep 2007
                        • 1901
                        Half moon spanners...
                        God, V-Bands are so simples
                        Le Mans 2012
                        Nurburgring 700
                        1995 S2 Avant
                        • Dobby84
                          • Feb 2011
                          • 1169
                          whats the best way to bleed the turbo befor starting the car?
                          • mcandmar
                            • Apr 2004
                            • 5118
                            Best thing to do is unplug the injectors and crank sensor and turn the engine over to build up oil pressure.
                            91CQ20v - Gone to a new home
                            93UR-S4 - The Magic Carpet
                            94S2Bus - The Emerald Express
                            • Phil Payne
                              • Jul 2009
                              • 328
                              Mr Reeve is now shipping an even thinner-walled nut that takes a 14mm spanner.
                              • Dobby84
                                • Feb 2011
                                • 1169
                                Turbo is all running now, still smoking but hope thats just the oil left in the pipework from when the old one let go!
