New Poly Engine Mounts
  • bambridge
    • May 2009
    • 609
    Well, i have finally done the prototype poly engine mount.
    The reason for this is to make a slightly softer version than the solid track spec ones as some people dont like the vibration they can generate.
    I have put a poly section between the ally base and delrin top.
    Willg54 has kindly offered to fit these to his car and test/try them
    Hope to get some feedback from Will soon
  • Knight Rider S4
    • 3541
    How much you wanting for them?
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • willg54
      • Jun 2009
      • 2055
      added pressure to get my car built up!! its all sitting waiting to get put together now...just need another 20hours in the days
      cant wait to try them though!
      • Thuppu
        • 4115
        Looks really PRO!
          mmmm - snazzy looking bit of kit
          • s2driveruk
            • 12696
            nice one - they look fantastic. How much stiffer are they likely to be over the stock mounts?
            1992 3b S2 Coupe
            • Rikki Kitto
              • Feb 2010
              • 6276
              I'll have a set please, thanks
              • bambridge
                • May 2009
                • 609
                These will be £140-00 a pair delivered in UK.
                Hoping that these will be a slightly less stiffer than the track spec ones but without the vibration
                • irishs2
                  • Apr 2009
                  • 2455
                  These look great. I will definitely want a set for the avant. What about gearbox and diff mounts, any plans?
                  Eric
                  95 S2 Avant under rebuild.
                  • A80Avant
                    • Sep 2005
                    • 10873
                    • Country: Greece
                    it would be interesting to make a shorter version for strokers+ reverse inlet manifold. Easier clearance...
                    if they dont vibrate, then they are worth it!
                    • bambridge
                      • May 2009
                      • 609
                      Do you mean these
                      Currently being tested by Brian Tonks
                      • bambridge
                        • May 2009
                        • 609
                        [QUOTE=A80Avant;580510]it would be interesting to make a shorter version for strokers+ reverse inlet manifold. Easier clearance...
                        Thats no problem
                        • A80Avant
                          • Sep 2005
                          • 10873
                          • Country: Greece
                          Ah that is convenient for me!!! ill ask him about his impressions!
                          • A80Avant
                            • Sep 2005
                            • 10873
                            • Country: Greece
                            by the way, which is the one engine mount which has one side being longer and oval in shape in order to move around? is that specific to the rs2?
                              Kevin,
                              Looks lovely, what about road spec ones in due course?
                              i.e. engine and gearbox.
                              Us older folk still want comfort in a daily driver, non track car, but still want it like new oem + .
                              Keep up the excellent work either way. Love your track rod adjustors btw.
