New Poly Engine Mounts
  • Sonic
    • Jul 2006
    • 5514
    Look excellent, when are sets for use with the reverse inlet as suggested by vas likely to be available?
    S2Forum.com Administrator
      Agreed, good call Vas, (in road spec also).
      • Billman
        • 4129
        [QUOTE=bambridge;580512]
        Originally posted by A80Avant
        it would be interesting to make a shorter version for strokers+ reverse inlet manifold. Easier clearance...
        Thats no problem
        Take care....when they are shorter the subframe comes closer.
        Go Holset or Go RS4
        • A80Avant
          • Sep 2005
          • 10873
          • Country: Greece
          i see
          well in my engine even with the phenolic spacer in, it fits now, but if it were a stroker... no way!
          as i dont plan to stroke, i should be fine with what i have, however, when i tried to replace the engine mounts with the 034 street density mounts, they wouldnt fit and they would raise the engine as well! they were taller than OEM.
          SO these ones should at least NOT be taller than new OEM ones.
          • bambridge
            • May 2009
            • 609
            Just need to wait till Will gets them fitted and tested before we go any further
            • willg54
              • Jun 2009
              • 2055
              Hopefully after formula student UK next week, i'll get chance to start building it all up again. I'll get the engine in first so I can at least feed back on idle vibration pretty soon.
              Shouldn't be too long though!
                Originally posted by bambridge
                Do you mean these
                Currently being tested by Brian Tonks
                You'll be hearing from me end of month for a set of the shorter versions
                • willg54
                  • Jun 2009
                  • 2055
                  Just opened the parcel and I have to say, they look AMAZING!!!
                    Any feedback?
                    • willg54
                      • Jun 2009
                      • 2055
                      Sorry Jamo, not as yet...off to Germany next week then its full attack on the build.
                      If you want to see them i can meet you in birmingham somewhere if you'd like?
                        No problem I think these will have to be put into the September purchase plan
                        • bambridge
                          • May 2009
                          • 609
                          I will have another pair ready in about 2 weeks(goin on holiday 2moz) if you want to test some Jamo
                          • GT500
                            • Jun 2006
                            • 2181
                            Send them my way as I acutally use my car every day in summer.
                            Rob..
                            87 UR 20v ABY
                            97 S6 Avant
                              The offer was to me gt500! Hehe I can do yes Bambridge I use my car daily also
                              • willg54
                                • Jun 2009
                                • 2055
                                Engine and gearbox is in and the engine is sitting very nicely
                                Should be up and running pretty soon. Sorry for the delay...you know how these builds go!
