Methanol boils at around 64.6c iirc and is not soluble in oil based compounds. I'm personally only reporting a find that appears to be constantly co incidental and therefore makes me wary.
Only time I've used water injection personally is on a supercharged blow through carb v8. Where we ran a 12 gallon fuel cell filled with water. The injector sprayed onto the blades of the compressor wheel and the outlet of the charger travelled a grand total of less than a foot into the carb. No intercooler or chargecooler it was very effective into the 4 fig power band. It was also not a road car
As for controllability, the aquamist systems do appear to have the upper hand at the moment if you can be bothered to learn to program them properly. Much the same with Apexi boost controllers learn to use them properly and they are blinding don't and you get problems.
