Heat soak is a proper pita and in general we can only get 95 RON here in Ireland.
Based on these fixed conditions and the results being less boost, more chance of knock, less timing advance etc it surprises me that water meth injection isn't a standard upgrade on our cars if everything I read about it is true.
Therefore I invite those that are using a system to detail their experiences of hardware and software in a single thread. Everything from installation issues to consumption settings to operating parameters.
In addition I have some questions (as always
) which have been drifting around in my mind for a while.
What is the power consumption of the high pressure pump and can you feel the car providing power to it when it's engaged?
Is there anything needed in motronic to achieve the best from the system. If the injection is far enough away from the IAT sensor that the water meth fully mixes with the intake air then is there anything else to consider.
What is the best water / meth mix ratio? I've seen 70/30 and 50/50 mentioned in a few places?
The controls I've seen in some online shops seem to be far from optimised.
Could one of the motronic hackers consider the possibility of using a pid type control circuit to always optimise the delivered IAT. For instance locate another IAT sensor pre and post the intercooler and a little scale to decide what action if any that the water / meth migh take. Likewise it could take a feed off a wideband exhaust sensor or EGT sensor and determine what input could be made to optimise the situation. I think the current systems make decisions based on user provided settings based on boost and throttle position sensor.
All input and links greatly appreciated. Also if anybody in Ireland (north or south) has a system running I would appreciate the opportunity to see it in operation sometime.
) which have been drifting around in my mind for a while.What is the power consumption of the high pressure pump and can you feel the car providing power to it when it's engaged?
