water / methanol injection questions
  • s2_wot
    • Aug 2006
    • 2178
    #61
    Prj, do you have any dyno data on any sort of turbo car with a before and after WM. I don't doubt for one second what you're saying but I can't seem to find that comparison anywhere.
    If you take the high end stuff like the aquamist product mentioned earlier I can't understand why that information isn't all over the place.
    http://www.usplastic.com/catalog/fil...wings/9684.pdf for future reference, 8 gallon tank.
    Shane
    • Bruce-m
      • Aug 2011
      • 11
      Jimbo's thread on Audisrs I believe has a before and after
      My Garage
      • s2_wot
        • Aug 2006
        • 2178
        #63
        Found it:
        http://audisrs.com/about14867.html&p...sown&start=240
        and borrowed a pic posted by Doug:
        Shane
        • Bruce-m
          • Aug 2011
          • 11
          A nice 45.3 ps gain and 32NM with a nice chunky extra engine security from cooler temps and better octane
          My Garage
          • Jonas_R
            • 3780
            • Country: Denmark
            #65
            Bruce-M:
            Your DVC-30 stage 2 kit with 30 PSI boost controller is that absolut or relative boost?
            Sleeper S2 Avant +450
            A6 Avant 2.7t Stage 3
            Audi S2 Coupe RS2'ed
            • Bruce-m
              • Aug 2011
              • 11
              Absolute boost, they don't read vacumm.
              My Garage
              • prj
                • Mar 2010
                • 6308
                I will try to get some, but can't promise anything.
                • Jonas_R
                  • 3780
                  • Country: Denmark
                  #68
                  That means around 1.4 bar as max boost on the controller if vacuum is 0.7 bar. That is not much I guess.
                  I'm running close to 1.9 bar boost so I guess I would need your DVC-100 instead then?
                  • prj
                    • Mar 2010
                    • 6308
                    How are you planning to tune Motronic for water/meth mix if you don't map switch?
                    You'll just run rich and lose power... Controller needs some sort of output to show if it's on or off... at the very least.
                    • Bruce-m
                      • Aug 2011
                      • 11
                      They don't read vacuum only positive boost so the DVC-30 is designed for up to 2bar boost (30 psi), you won't need the DVC-100.
                      My Garage
                      • Bruce-m
                        • Aug 2011
                        • 11
                        Jimbo didn't tune for water Meth and switch maps & look at his gains, no loss there.
                        My Garage
                        • Jonas_R
                          • 3780
                          • Country: Denmark
                          #72
                          Ok then it is not absolute but relative pressure since absolute pressure is measured from 100% vacuum.
                          • Bruce-m
                            • Aug 2011
                            • 11
                            Yes your right sorry, relative is the boost pressure a car is running.
                            My Garage
                              I want to update my water injection with the aquamist HSV1 solenoid valve and the inline relay if anyone knows where i can get them because Aquamist do a different kit now
                              • prj
                                • Mar 2010
                                • 6308
                                Yeah, and he was running ME7, not M2.3.2.
                                Nice comparing apples to oranges. ME7 fuel trims are completely different to M2.3.2, where there are none on boost.
                                If you have a tune that is mapped to run fairly rich, say 11.5, you will easily dip to high tens and lose power.
                                I mean, I don't mind you promoting your product, but you could do so abiding by forum rules (sponsorship) and without misleading information.
                                How many S2's have you mapped on meth?
