Couple of pointers....
1 - fuel pump does NOT prime on S2 so thats not a worry
2 - search the forum on building a fuel pump 'hacktivator' so you can test fuel delivery without running the engine
3 - the fact that S25 blows on cranking says a couple of things... firstly that pump relay is getting activated by ECU - which means it is broadly happy with RPM signal from G28 sensor... and secondly that some odd **** is happening cos either a loom fault is creating a short circuit on the S25 path - or the lambda probe heater itself is shorted.
4 - with ignition on, check you get 12V at one side of the fuel injectors and that the white 3-pin plugs on the POS connectors are also 12V.
Oscilloscope is the only way to ascertain if G4, G28 & G40 are healthy and aligned... I have posted plots of that in the past which will help any auto spark worth his salt even if he doesnt know any specifics on S2 wiring and such.
Are you certain its not some immo/security issue ?
