Should be between 2.3L and 2.4L.
Someone should really take a scientific approach to calculating this.
But the lower compression ratio and the fact that you can run 30+ deg timing while it is spooling up without getting knock really helps spool as well.
Of course not on these graphs, because here it is spooling early in the rev range, I mean if you suddenly floor it at 4000 rpm for example.
