modified kkk24 7000 turbo
  • #16
    Hoffer, are you planning on producing a chip for these on S2/RS2 hardware
    • #17
      Originally posted by hoffer76
      the comp wheel has far more modern design and 40% lighter so the spool is FAST
      been running 1.5 bar dropping to 1.2bar and feels easy 300bhp should have some dyno time coming up soon so I can see what limits are.
      Seems good, forgive my uneducated mind here, but is that a straight swap old turbo for new and bingo much more power?
      • #18
        been running on tweaked 303 chips as the turbo spec is very similar to sms hybrids they run sweet
        • #19
          straight swap will only give slight increase in power but noticeable spool improvements.
          add chips then power comparable to standard rs2 without the lag.
          • #20
            Hoffer, are you running this with a larger intake airbox or a cone filter? Very interested to see some comparative graphs and also everybody's thoughts on the chances of bending rods. RS2 performance without the lag!!!
            Shane
            • #21
              Zero chance of bending rods
              • #22
                Is there a guideline compressor map for this setup ?
                Would be great to know if it can safely run into say 1.7bar in the mid range... Then modified RS2 chipsets with 3bar MAP could make a sweet option too. But if the limit is 1.5bar then thats not worth pursuing. Injector headroom is another thing to consider.
                • #23
                  injectors and map sensor are why I stuck with 1.5 bar also my feeling was that if you want more than 310bhp you need rs2 or better manifold, injectors, intercooler, exhaust so you may as well use rs2 turbo.
                  • #24
                    I have a question, so chip that I will receive with this turbo will be SMS chip or a copy of these or a copy with some custom parameters or what? And difference between this and SMS hybrid turbo mount on S2 SMS Revo S2 Coupe ABY?
                    If I want mount a RS2 setup with RS2 hybrid turbo what can you tell me about turbo lag difference between K24/7000 hybrid and K24/7200 hybrid? Is the difference like between standard K24/7000 and K24/7200 turbo?
                    Thanks!
                    Bye
                    Alessio
                    My life and my loves
                    Audi-Porsche Avant RS2
                    Audi S6 C4 ABT Avant
                    Audi S2 Coupe ABY
                    Audi S2 Avant
                    Audi Cabriolet 2.0E
                    • #25
                      Any update on this thread from anyone who has one fitted, or a dyno plot from Richard.
                      Thanks.
                      • #26
                        now this is a nice turbo to complement my (yet to be installed) wagner IC and (yet to be purchased) wagner reverse IM
                        • #27
                          How will this turbo perform in a homefried car?
                          *95' Clio Williams
                          *94' 19 16valve
                          *94' S2 Avant
                          • #28
                            It needs a different map.
                            • #29
                              Thanks.
                              Mine is in and needs a remap and a few other things to make it work properly. I went for a slightly different spec to Richard's original so have to wait and see how I get on...
                              • #30
                                Originally posted by Rusty
                                .... and a few other things to make it work properly....
                                such as......
