Problem is you've broken the spool ceiling on the 2.2 to get 600 bhp you're in 4-5k spool area, below it you can run to 550 with a 3-4k spool 2.2 engine
I'd more look at your cam setup rather than a new turbo to see if you can get a better spool
Okey, that´s what I thought.. I´m running 7a cams but will go over to cat cams instead!
My goal is 500bhp after tuning it..
Running a pair of 7A cams increase lag in stock timing, the alternative is reclock them per Audi_CQ suggestions ( need adjust cams sprockets and wheels ) .
I'm running the HX40 Super and 1bar seems to be at ~4250rpm, not yet mapped. This is a 600+hp turbo.
Billman, you'r right. I have a size #16 housing, in A/R sizing it should be something between .80 - 1.00.
