went to order mfts today, and found that there are new part number, wasnt ordering of audi, but a good german parts supplier, 035919 369 L , 4 pin MFTS, far i as i know the new one has three pins, am i still good ?
Mfts
The 035919369L was dropped on Aug. 31, 1992 in favour of a 046919369, i.e. 20 years ago. In turn the, 046919369 was dropped on Dec. 31, 1993 in favour of the three pin 034919369C. This is the part number you want to use.
94 UrS4 V8 6 spd manual avant -
Thank you. i have it ordered as well as other sensor in 3b water manifold for good measure.. will double check part # at store counter when i collect. thanks againThe 035919369L was dropped on Aug. 31, 1992 in favour of a 046919369, i.e. 20 years ago. In turn the, 046919369 was dropped on Dec. 31, 1993 in favour of the three pin 034919369C. This is the part number you want to use.
1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
Like the Thermal Switch that activates the After-run pump?
quattroworld.com Forums: After-run Auxiliary Coolant Pump and Fan Switch and 324 Control Module InfoThe Audi Enthusiast website. Forums for all Audis including A4, S4, A5, S5, A6, S6, allroad, A8, S8, TT, R8, Q5, Q7, 4000, 100, 200, v6, v8, vintage, local forums
Hello
Up this thread because i ve ordered the 3 pins one for my 3b
But after installed it my water temp goes over the normal temp without starting the fan on ...
Is there a trick to check the new sensor ?
I ve put back the old 4 pins one and it's back to normal operation
:what:91' S2 3B Pearl WhiteComment
Fan runs from the otter switch in the bottom of the radiator, not from MFTS.
MFTS has several jobs according to the book..
Reduce boost pressure when temp is over 119degC
Coolant temp indication.
Engine temp warning
Climate control.Comment
Ah, just read again, so what you're saying is the temp gauge is over-reading?Comment
Maybe an intermittent short in the wiring plug?Comment
If its a miele made one,they seems to be a general concensus that they over-read massively.Had this problem myself,swapped back to a behr one and normal temp reading.Rob
Ragussa green avant RS2+ spec
Racing blue Octavia VRS mk2 estate-Remapped now to 250 bhp
Audi coupe gt-slow as hell but loads of character-sold
