Another one
Okay, now I am starting to get depressed.
Someone I know who had their serpentine belt break on the road said I should add it.
n. Serpentine Belt The AAN and ABY accessories, e.g. PS/PB pump, aircon, alternator, etc. are run off a serpentine belt. If the belt breaks, you have none of the above. If the broken belt doesn't take out the timing belt (it can and has), you can still drive the car (with some extra effort) but eventually the battery will go dead flat and you are done.
Solution: Pre-emptively replace the belt if the miles since the last replacement are high (e.g. 100K mi (160K km)) (A/C equipped, 054903137B,6 rib 21.36 X 1693MM or Non-A/C Serpentine belt (i.e. non-North American or A/C delete)= 054903137A, a 6 rib 21.36 X 1293MM) or carry one with you in your spares box. However, since the serpentine belt can take out the timing belt on its way out of the engine bay (killing the head), the pre-emptive solution is better. They aren't that expensive and take only a few minutes to change.
More info here: http://forums.quattroworld.com/s4s6/msgs/22579.phtml
Someone I know who had their serpentine belt break on the road said I should add it.n. Serpentine Belt The AAN and ABY accessories, e.g. PS/PB pump, aircon, alternator, etc. are run off a serpentine belt. If the belt breaks, you have none of the above. If the broken belt doesn't take out the timing belt (it can and has), you can still drive the car (with some extra effort) but eventually the battery will go dead flat and you are done.
yesterday) bottom intercooler hose blowing off! was on a hill surrounded by heavy traffic....grr!
- Hope all is well UrS4boy
