Aquamist HFS3 in my Audi S2
  • URquattroGus
    • Aug 2007
    • 547
    How was the kit to fit rocco? Easy diy? Specifically the wiring.....
    Angus
    (1984 ur quattro)
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      it takes many hours if you are doing a nice fitting job,like if you were doing a surgery
      also,you need to build a custom tank,wiring,adapters,study how to wire everything and where... and the last step test and try... now is working like it should but the system has lot of features about how to setup. then you can play putting one,2 or 3 jets....depends on your taste
      i am sure than DD will put another extra 50Hp at the crank with this
      • Jonas_R
        • 3781
        • Country: Denmark
        Prj:
        What is your opinion about using denatured alcohol instead of methanol?
        Sleeper S2 Avant +450
        A6 Avant 2.7t Stage 3
        Audi S2 Coupe RS2'ed
        • Rocco
          • Aug 2007
          • 6393
          • Country: Spain
          Well,I have found this in the aquamist forum.
          I'm not an expert but I'd like to can interpret those graphs.
          Dmitri,what do you think about this?
          We are looking for the best water/methanol mixture ,so looking at graphic it seems that water is cheaper to buy and has better features true?
          What do you think guys?
          • Smiley
            • Jun 2005
            • 329
            From what I've heard, some people are (mis)using the screen washer tank...
            '93 Audi S2 Avant panthero black, 412.000km
            '94 Audi S4 C4 Avant 303Tkm, KW, Brembos, BN-Pipes, Bose, S6 front (sold)
            '93 Audi S4 C4 Avant, 260Tkm
            '88 Audi 100 Avant turbo 44Q
            '84 Audi 80 quattro tornado red
            • A80Avant
              • 10873
              • Country: Greece
              #21
              i am using the screen washer tank. no problems. So long as its clean and not previously used with different fluids.
              • Jonas_R
                • 3781
                • Country: Denmark
                #22
                Vas:
                mix of meth/water or just water?
                Also do you use the washer fluid tank for tje windscreen as well?
                My plan was to run a 40/60 mix of denatured alcohol and water and use it for the windows and the car
                • A80Avant
                  • 10873
                  • Country: Greece
                  #23
                  i use no more than 20-30% methanol and only the front windscreen washer bottle. 5lit big and works nicely.
                  • Jonas_R
                    • 3781
                    • Country: Denmark
                    #24
                    Yeah ok so you have two windscreen washer bottles?
                    • A80Avant
                      • 10873
                      • Country: Greece
                      #25
                      The avant has 2 one for front one for rear
                      • Henkjan
                        • 1705
                        do you have any photos?
                        • Rocco
                          • Aug 2007
                          • 6393
                          • Country: Spain
                          #27
                          yeah i did few,very few
                          i will check
                          • jorge s2
                            • Feb 2009
                            • 226
                            • Home: Portugal Current: Spain
                            #28
                            And the coupe has 2 haswhell , for sure my aby as 2 botles 1 rear and one in the the front.
                            audi s2 aby red 1993 powreded by prj
                            • prj
                              • Mar 2010
                              • 6308
                              http://www.aquamist.co.uk/vbulletin/...ead.php?t=2187
                              100% meth will always make the most power.
                              End of story.
                              P.S.
                              Latent heat != cooling. Meth cools the intake charge much better than water, due to the boiling point.
                              • Rocco
                                • Aug 2007
                                • 6393
                                • Country: Spain
                                #30
                                Ok,we will try different mixtures then
                                Got 50 liters of water and methanol ,37 EUR for all.25 water/25 meth
