I'm doing 20v conversion on my 1985 ur quattro, engine is fitted and mated to ur quattro 5 speed gearbox.
I'm using flywheel from 3b and cluth plate from ur. Realese bearing from ur also. (flywheel machined out to fit on crank)
What it is i have no cluth, while engine is runing i can put in any gear i want without tuching the clutch pedal.It is little bit of crunch noise if i try to go in reverse, but still possible.
While in gear i can stop driveshaft by hand but they spining if not held.
Had a gearbox out today again and swapped the realese bearing for thiner one. Had a slave cylinder out( new) and checked if it is any play on realese bearing between the bearing and presure plate. It is few mm. So i presume bearing is not pushing on presure plate.
I run out of steam and have no ideas what else to check or measure.
Any ideas, or advice??
Thank you
Thank you
