00561 and low boost
  • twoqu
    • Sep 2003
    • 3103
    So what if anything has changed since the last dyno? Link here in case thats of any help:
    Seem to recall that the lambda is only concerned with idle mixture and perhaps cruise, it does not monitor the mixture full time. Could be wrong Worth verifying.
    I think the TPS is involved in boost control so might be worthwhile looking at its function and checking its operation via Vagcom.
    • twoqu
      • Sep 2003
      • 3103
      I was close!
      • sjw185
        • 1175
        [QUOTE=twoqu;691390]So what if anything has changed since the last dyno? Link here in case thats of any help:
        I found the fault with the injector and replaced the following components since then:
        Injector
        Replaced atmospheric DV with 710
        Replaced vac pipe work
        Fitted fuel pump
        Fitted new fuel filter
        Repaired fuel lines
        Fitted wgfv (mac valve)
        Fitted new flow regulating valve on breather pipe work
        New spark plugs
        New coil
        3"downpipe and scorpion exhaust
        I did check the throttle pot resistance before and it was ok
        • prj
          • Mar 2010
          • 6308
          Good luck making any proper boost with that...
          At least I was unable on a few cars. Fitted back N75, problem solved.
          TPS is verified using VAG-COM measuring blocks.
          • twoqu
            • Sep 2003
            • 3103
            #20
            But basically in comparing the two dyno tests you have less boost and a weaker mixture now.
            Pretty sure in Vagcom there is a chanel for the TPS which is what the ecu see's rather than the resistance if you see my point.
            Did you do the exhaust after the first dyno?
            • twoqu
              • Sep 2003
              • 3103
              #21
              Think Dmitri has a point!
              • sjw185
                • 1175
                Yea that first dyno had the original system including cats.
                Was quite excited about getting the new system with no cats but no improvement was felt
                Will check the TPS in the morning
                Steve
                • sjw185
                  • 1175
                  I didn't think these valves were a issue never heard any bad reviews about them.
                  Looks like I will be giving Mesel some extra Christmas presents.
                  Steve
                  • twoqu
                    • Sep 2003
                    • 3103
                    #24
                    Moral of the story is to look back at 'The improvements' you have made since the car ran properly!
                    Lets hope its something as simple as the N75.
                    This might help to eliminate the TPS.
                    • sjw185
                      • 1175
                      Good point, Ive not worked with the car for a year really and because I work offshore I do some stuff with the car then it gets left for a few months then i forget where im at.
                      Thinking back I never got 00561 until I changed the exhaust system Dec last year.
                      cheers
                      Steve
                        Maybe the O2 sensor got disconnected or damaged in the process?
                        • sjw185
                          • 1175
                          Possible, will also check exhaust system for leaks around the downpipe if this effects the lambda readings?
                          • twoqu
                            • Sep 2003
                            • 3103
                            #28
                            Looking at the possible causes for the code, one is of an exhaust leak up to the catalyst!
                            I wonder if the limit not reached is basically indicating a lean mixture which the lambda cannot control. Whether that is down to the exhaust/downpipe improvements or a leak remains to be seen.
                            That fault comes up regularly and seems tricky to nail down with Lambda replacements only temporarily curing the problem. We know the RS2 had a less restrictive exhaust but perhaps whatever map controls the Lambda needs a bit more tweaking to eliminate that particular fault code.
                            Not sure if that code has any effect on the rest of the range other than at idle. Be interesting to know!
                            • AndyP
                              • 6049
                              When you did the boost leak test, did you check the vacuum lines? If not, try this
                              You'd be suprised how even the tiniest leak on a vac line can cause the car to run like s**t.
                              • prj
                                • Mar 2010
                                • 6308
                                My vote is also that it has a boost leak, coupled with a few other problems.
                                It should not run that rich at only 1 bar of boost. It should run this amount of fuel at about 1.8 bar.
                                At 1 bar you would see 13 AFR or so.
                                This together with the lambda code tells me that there is a leak somewhere and that the pressure test was not performed correctly...
