Audi RS2 timing or belt question
    Originally posted by twoqu
    Another check might be to calculate what one tooth of the cam sprocket equates to in degrees. If its in the 10 degree region I think that stacks up.
    There are two (or three) issues here.
    1. The cam lobes on an RS2 exhaust cam are located 10 degrees away from the AAN/ABY exhaust cam lobe position.
    2. Ignition timing is supposed to be the same relative to TDC on the ADU?AAN/ABY so the shutter wheel opening has to be rotated 10 deg to compensate
    3. The thing with the 26 tooth water pump and the 150 tooth cam belt somehow messes up No.2 on the ADU, requiring a slight shift (less than a tooth to the left looking from the front).
    BTW one tooth = 6.92 degrees (=360/52)
    • minim
      • Aug 2013
      • 201
      • Country: Norway
      #92
      Originally posted by AndyP
      I agree, I've got a huge 3/4" torque wrench and I still can't get 180°, time to eat more pies I guess!!
      Went and bought 3/4" and I got 180° now that things didn't crack between my hands anymore
      I think the issue is this 10 degree difference. As far as I am aware the cams would be aligned only if the TDC mark on the pulley was at the ABY not the RS2 position. I will have to look more closely but unless Audi/Porsche took the time to remark the inside of the pulley then its not going to match when installed at the RS2 position. Don't forget that as the inlet cam is identical to the ABY (I believe) then the only way to get the published difference in the timing is to physically move it. Once you move it the marks don't line up! All of this could have been avoided by putting the marks in the right places on the pulley.
      See what others think whilst I check the marks!
      It could be. I didn't mean that it was one tooth out on the chain but one tooth out on the belt. It's more than one on the chain I believe. It's a nightmare getting things done correct when the marks are in the wrong spots ^^
      • minim
        • Aug 2013
        • 201
        • Country: Norway
        #93
        Reply to 3.
        Yes, when I check the cam cover it is indeed half a tooth out like it was when I started this so it's spot on according to the picture from page 1 in this thread where it shows where it should be. The only problem is that in that position the cam's are not aligned at all. The first pics in my post with pictures of cam alignment shows how much off it is when the cam pulley is half a tooth off the mark.
        • minim
          • Aug 2013
          • 201
          • Country: Norway
          #94
          Posting this so others don't have to search. This guy seems to have the same problem as me. Here is a link to the thread.
          I think my intake cam should be moved one tooth on the chain and then it would prolly be just a half tooth off again.
          • twoqu
            • Sep 2003
            • 3103
            #95
            An alternative way to look at this is that you have not changed the relationship between the camshafts or the engine timing. All you have done by using the correct pulley is to put the hall sensor rotor back to the correct position for the RS2 which we are hoping cures some of your issues. Therefore you have not changed the physical timing during all this.
            Even those dots on the cams are not that accurate because even when you align them they shift during tightening the camshaft caps. There are some pics on here somewhere. Unfortunately its all rather unsatisfactory and not very precise.
              Okay, my head is officially going to explode. (Please help me!!)
              I did a better rotation of minim's RS2 ADU 034109195B cam sprocket and now I don't like what I see. Hopefully, I am just confused. See below.
              First, we start with the AAN sprocket again. Note where the lines between teeth 6 and 32 and 1 and 27 strike the shutter wheel relative to the shutter wheel opening.
              Now look at the revised annotation of the ADU 105B sprocket. It appears to me that the ADU shutter wheel opening location is rotated one tooth (= 6.92 degrees (= 360/52) relative to the lcoation of the AAN shutter wheel opening (using the 6-32 and 1-27 lines as reference points). Where my head wants to explode is the ad hoc adjustment of the ADU sprocket about one tooth to the left (anticlockwise from the front or clockwise to from the rear). This means that ADU exhaust cam lobes are brought back to the same location as the AAN cam. WTF?? (Hopefully I am just confused)
              • twoqu
                • Sep 2003
                • 3103
                #97
                Look at the first pic in post 21. The only other issue is perhaps the timing chain has stretched.
                  I see that but it doesn't deal with the compensating rotations that I think are occuring.
                  Hard to do this remotely without the physical in front of you.
                  The photo I presented in post 21 is not mine. Unfortunately it's cockeye'd relative to the top of the head, making "accurate" assessments difficult. Here it is again with some annotations:
                  • twoqu
                    • Sep 2003
                    • 3103
                    #99
                    The comment I made was for the OP!
                    Still trying to fathom what you are going on about! Lets sort this out and then if necessary start a new thread.
                    • minim
                      • Aug 2013
                      • 201
                      • Country: Norway
                      #100
                      Ouch. What I see there scares me a bit. If you look closely the mark on the pulley is at the edge there when the O's are lined up. Mine is one tooth down when the O's are lined up. There is nothing I can do about this issue except changing my exhaust cam, but I did measure it and it had the correct lift for ADU so..
                      Edit: after looking a bit more on it I think the picture is taken from a angle that makes it look like the mark on the pulley is at the endge but it's actually below the edge.
                      After some more thinking tho I can't understand how I could set them to get this better. The O at the exhaust mark isn't lined up with the edge of the top before exhaust and inlet cams are lined up. This means that I can't get it any better than it is. I cannot move the pulley on the exhaust cam so this means I can't set it anywhere else to get things lined up... I'm just going to put it back together as it is now as this must be correct with the parts I've got.
                      • minim
                        • Aug 2013
                        • 201
                        • Country: Norway
                        #101
                        Comparing again... wtf's up here The picture attached by UrS4boy on the left side and mine on the right. The angle the photography is taken from on these two pictures are not that different and still.. on mine I can't see a mark on the pulley and on UrS4boy's picture I'm sure I see a mark. Do you happend to have a better quality on that picture UrS4boy so I could zoom and compare?
                          Minim: This is the way the cams are supposed to line up. If they don't you need to mark them, remove them (at least one, e.g. the exhaust cam) and rotate the cam by one tooth (as needed) and then re-install and check again.
                          • minim
                            • Aug 2013
                            • 201
                            • Country: Norway
                            #103
                            They do line up like that. Hmm maybe I'm wrong that are thinking of the mark on the pulley for the belt while aligning the marks on the chain pulleys?
                            They do align at the edge there but they do not align at the TDC mark. Maybe that is irrelevant but I don't know.
                            • Laaf
                              • Oct 2010
                              • 275
                              With the crankshaft set at TDC, the cam pulley set half a tooth as needed on ADU and the markings on the chain sprockets should then line up perfectly.
                              • minim
                                • Aug 2013
                                • 201
                                • Country: Norway
                                #105
                                Well they don't and there's nothing I can do about it with these parts. They do not align up until the cam pulley is about one tooth out. The position of the exhaust cam "O" marking is fixed as the cam pulley must be fit at the key hole that is into the exhaust cam. At TDC the exhaust cam is not aligned against the edge of the head so I have to move it about one tooth (on cam pulley for cambelt) out of position to get the exhaust cam "O" aligned with the edge of the head and when that is aligned the intake is also aligned.
                                I've now gone trough AAN workshop manual and what it says about camshafts installation. When installing cams the only thing they are talking about is aligning the two "O" marks at the edge. I'm not sure but from what I read there the aligning of the "O" marks doesn't have to be at TDC so it might actually be correct. At least there's nothing I can do to change this as the cam pulley is at a fixed position and as long as both line up at the edge I can't really change anything for the better.
