Car came with loads of history and bills for the regrind and parts for the rebuild, strangely the bill for the actual rebuild is missing
It seemed such a good bet with only 4k miles since the rebuild I didn't look that hard and neither did the chap I bought it from who only owned it briefly..
Incidentally the crank never had it's final grind, you can see and feel the grooves in the journals with your fingernail, it looks like a turned surface not a ground journal at all.. The bill for the grind was from Agra Engineering http://www.autoinsider.co.uk/local/e.../ai_101968.php
It seemed such a good bet with only 4k miles since the rebuild I didn't look that hard and neither did the chap I bought it from who only owned it briefly.. Incidentally the crank never had it's final grind, you can see and feel the grooves in the journals with your fingernail, it looks like a turned surface not a ground journal at all.. The bill for the grind was from Agra Engineering http://www.autoinsider.co.uk/local/e.../ai_101968.php
