Well today I finally managed to dig out my boost test kit I bought years ago from Andy p but never used, went to work and locked myself in the garage to try and finally solve this boost leak I've had for far too long.
Would you believe it, it was coming from my mark h mod ! I mean seriously......the one mod that you wouldn't expect to fail! It had an inch long split in it, no wonder I was only getting 1.5 rather than 2 bar !
My intercooler has no o ring so despite what I've read on here I will be fitting one along with another hose.
My test kit must of been an odd one out as the tyre valve is actually on the large bung that goes in the maf hose, so I pressured it from there, it would only hold pressure to 0.5 bar then would gush out the intercooler.
Now my other issue after the boost test is now I have a smokey exhaust, i only drove it for 2 miles to get home but am slightly worried I may have done a bit of damage ? I am aware it's a risk pressurising from the maf hose but thought that 0.5 bar would be ok as I've done it before , what's the chances the seals fooked or does it just need a good run ?
must of looked at this pipe a hundred times over the last 6 months and never spotted it, seems to be running better than ever so hopefully no more leaks fingers crossed for you to fella
