Hello.
The car has been on the Dyno today for mapping. car is running VEMS so I have done the mapping however the result for power is down on where I expected it. The figure shown on the plot is Crank HP 483.6 and 440 lb/ft peak torque. I was expecting somewhere near this at the wheels. Or am I being over optimistic.
The car is running a HX35 turbo.
what I think is a china Large intercooler (Got with the car when I bought it)
044 fuel pump relayed
custom reverse intake manifold, this uses the standard 3b runners into the cylinders.
intake and exhaust piping is all 3 inch.
Tubular Exhaust Manifold, screamer pipe and Tial v44 Wastegate.
v8 coil conversion
I have attached the dyno plot and also my vems log for the run.
The car to me seems to be restricted from 6000rpm as the torque and power drop off. it was always going rich at the top end on different boost levels indicating poor pumping / breathing efficiency of the engine. I think the restriction is on the inlet side, I suspected the Intercooler but Im not so sure anymore. could it be the inlet manifold? or the Cylinder head itself? the head is standard.
Another ting I have noticed in the Log is; the spark angle recorded is about 7deg more that the value in the indicated cell of the ignition MAP. For info It is not Knocking.
All comments welcome
Project thread was here with more info on the spec.
Alex
v8 coil conversion
Alex
However, I get that same boost 500rpm earlier, so it is a tradeoff.
