Dissapointing lag
1976 RD250E / 350LC cafe racerComment
I'm very happy with my mapping thank you
Tuners are a very personel choice, you'll hear good and bad about all of them, some of the bad stories are just worse than the others
GTX3071R on stock cams should have full boost just before or at 4k in 3rd, not after 4.5k. A GT3076R makes full boost at 4.1-4.2 in 3rd.
If it's making full boost at 4.5k something is wrong with your car, end of.Comment
what about asking to see if anyone can loan you a turbo to try before spending too much money?
do you know what power it was making? i know you say you set 1.5 bar on the boost controller, did it make 1.5 bar?
i am thinking along the lines of the wategate not sealing properly.
i would run it on the n75 until you are happy with it just to get rid of another variable.Comment
Ive recently had my car mapped and am also disappointed with the lag using a GT3071R which should spool quicker than your GTX I believe. At 4K RPM Im seeing 15psi. Im putting it down to the hot side of the turbo as I had it opened out from .6 to circa .7 to give more top end. This is using an N75.Evening gents,
However...lag is a real issue. Very little boost below 3k , and I don't think it's making full boost until well after 4k rpm. Mark wants me to change to a smaller turbo but iv gott be honest, I thought this setup would be ideal for a street car?
Any suggestions or similar experience?Comment
At 4k you should be seeing 30 psi. With a 0.63 hotside you should be seeing it at 3800 rpm.Ive recently had my car mapped and am also disappointed with the lag using a GT3071R which should spool quicker than your GTX I believe. At 4K RPM Im seeing 15psi. Im putting it down to the hot side of the turbo as I had it opened out from .6 to circa .7 to give more top end. This is using an N75.
Mapped plenty of cars with these turbos.Comment
My old 3B with a GT3071R had to be mapped with slower boost ramp-up to prevent surge. It was crazy, trying to make full boost around 3500rpm if i recall. After mapping it was making it at 3800rpm and spooled up damn quick!
I need to stop thinking about it, car is off the road longer term now and it's tempting to start fettling with it
Above 3k the 3071 really starts to go for it, 2 Bar at 4k is right.Comment
I would lose the 7A cam(s), swap out the turbo for GT3071R (0.63) for a target of 450bhp territory and desire for strong mid range torque (as opposed to max power up top).Paul Nugent
