Oil pressure sensor - NLA and what to do
This is a sticky topic.
    I was researching into oil pressure sensors (for a guage - not a lamp) on the B6 S4 and discovered that the 035 919 561 fitted to the 3B/ABY/ADU is well and truly NLA.
    This is the bigger/chunky 2-pin sensor that is wired onto ABY as follows:
    'G' - black/white - 0..5 bar based on variable resistance - G10 on schematics
    'WK' - blue/black - this is a n/c (normally closed) switch that OPENS with pressure above 0.3bar - F22 on schematics
    In conjunction with the hybrid F22/G10 unit, we have 056 919 081 E as a single pin (n/o) switch that CLOSES when oil pressure exceeds 1.8bar - this is 'F1' on the schematics connected to a white/grey wire.
    Both devices have an M10x1.0mm threaded fitting on the left side of the block.
    The problem we have is that an alternative to the NLA part looks to be 035 919 561 A - this was fitted to many an old Golf and Audi engine (including KW, MB, NG, KV, NM & 7A), BUT it has a different setup on the switch side which prevents 'plug and play' operation.
    The switch 'WK' side of the 035 919 561 A part is actually the 1.8bar n/o switch... so on S2/RS2 we will get false oil pressure warnings as the logic is back to front on our autocheck system.
    The FIX is to swap the switch wiring around on the ABY and fit an alternative to the 1-pin switch in the F1 position as 028 919 081 D (or H) - these are 0.3bar n/c switches what get wired to the blue/black wire so that Autocheck behaves correctly.
    If that isn't clear for anyone, I shall create a lil diagram !
  • rynaqui
    • Mar 2012
    • 2752
    • Country: Malta
    I got one very recently from quattro corner, OE and same part number 035 919 561.
    But this fix can save us in the future, good work Paul
    1996 S2 ABY Silver
      Pete maybe has some of the last OE items available then - just be especially careful when sourcing aftermarket replacements - the most popular application will be on old Golfs and they will be 'wrong' for the S2/RS2 and need the fix described above.
        I used a aftermarket VDO unit. Its the same spec except M10x1 taper thread:
        • customizer
          • Apr 2014
          • 24
          Good info thanks for posting
          • S2_avant 19930325
            • Mar 2019
            • 648
            Hi Paul , how do you mean it should be done ?? I think i have exactly this problem on my car. Could you make somkind of easier diagram ?? Thanks a lot.
            • rxl
              • 1913
                • Dec 2017
                • 5987
                I did find an aftermarket one that worked correctly. It's somewhere in my Nothelle thread.
                • S2_avant 19930325
                  • Mar 2019
                  • 648
                  ok ,, but if i can switch wires and make it work , its better then 100 euro
                    • Dec 2017
                    • 5987
                    • le mans
                      • Nov 2013
                      • 165
                      • Country: New Zealand
                      FCP euro sell aftermarket ones. I have an FAE one and it works perfectly.
                      https://www.fcpeuro.com/Parts/?keywords=035%20919%20561
                      • S2_avant 19930325
                        • Mar 2019
                        • 648
                        i saw all the pages ,, ufff,, great info ,,, thanks a lot.
                        • S2_avant 19930325
                          • Mar 2019
                          • 648
                          I can find FAE in sweden and if they work i can go with them ,,, great ...
                          • S2_avant 19930325
                            • Mar 2019
                            • 648
                            This should work ??
                            This gallery has 1 photos.
                            • johne
                              • Apr 2007
                              • 1405
                              This thread gives an alternative solution of fitting a "T". With that in place you can fit an individual oil pressure switch with an individual oil pressure sensor.
