Massive oil leak due to the oil pressure switch
  • CoupeWannabeS2
    • 403
    Recently started losing a lot of oil, and left quite a trail behind me.
    Thankfully I wasn't far from home when the oil warning light started showing, so managed to limp home.
    After removing the coolant, radiator, fan, old air-con radiator, and plastic cowling I managed to get to the oil pressure switch - the source of the problem. Now getting the stuff I need to put everything back together. Also cleaning everything up - as it was quite a mess in the engine bay as you can see.
    I did remove the oil pressure switch, and further oil started leaking. I quickly put it back, but wondered if there is much oil that will leak from here? I was thinking that there can't be too much - as its a higher point than the sump, but thought I would ask.
  • Bowie69
    • Nov 2013
    • 2675
    Mine did similar on way back from alignment, same day as its first MOT in 4 years(!)
    Don;t think I stripped anything out, just got in there with a short spanner and swapped it out, and no, not much oil will leak at all, and you have a white one, you may be asked which you have at the motor factors, either white or blue are the options I think
      Things that will fail on your 20VT and strand you at the side of the road
      While the engine is running, oil will leak from a damaged switch like that because it is under pressure. With the engine off, it will leak due to the oil draining down (somewhat) from the head.
      This is a well known point of failure for many water-cooled VW and Audi engines. Always good to replace them before a long road trip, or at least carry a spare.
      Item 8 in "Things that will fail on your AAN, ABY or ADU and strand you at the side of the road":
      • 220bhp
        • 2578
        • Home: United Kingdom
        Sorry you are having problems Dan. At least its a fairly easy fix, apart from cleaning up the mess. It might be an idea to replace both the switch and the sender while your in there. Give me a call if you need any help.
        • CoupeWannabeS2
          • 403
          Thanks for the replies - and offer of help Lou, I should be ok, but will drop you a line if things go wrong!
          I stripped the coolant system out to give it an overhaul as well as getting near the faulty oil switch. I think I have a slight coolant leak aswell, so figured I might as well take the car off the road and tackle several jobs at once.
          Got a new oil switch on order, aswell as coolant, and a new thermostat (which appeared to have been the original looking at the date stamped on it).
          Loving the photo of that engine - mine is never going to look that good!
          • Rikki Kitto
            • Feb 2010
            • 6276
            If you're looking at coolant I would defo put new O rings in the water inlet manifold cost about £10, 3 O rings and 1 triangular type thing
              Are you running an aux rad? If so I've got the upper aux rad hose from the Samco water kit going spare
              • vonbeck
                • 2455
                Mine went last year bit of a pig to do I was surprised myself with the amount of oil thought it was something really major
                Sent from my iPhone 5
                using Tapatalk
                ABY Cricket Green Pearl Coupe, blk leather
                THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!
                • mcandmar
                  • Apr 2004
                  • 5118
                  Ahh that old chesnut. Replace that bit of coolant hose from the thermostat while your in there as it doesn't look too healthy.
                  91CQ20v - Gone to a new home
                  93UR-S4 - The Magic Carpet
                  94S2Bus - The Emerald Express
                  • CoupeWannabeS2
                    • 403
                    I have deleted the aux radiator recently, but thanks for the offer.
                    • CoupeWannabeS2
                      • 403
                      Yes - I did notice it looked a bit tired. Will look to get it changed whilst I can get at it.
                      • Michael S2
                        • Dec 2011
                        • 1378
                        Worth changing the other small hose for the turbo return to water manifold while your in the area.
                        1995 Audi S2 Avant
                        • CoupeWannabeS2
                          • 403
                          Thanks, I will do that. When I get a minute I will take the hoses off so I can get the correct sizes.
                            Turbo coolant line info including rubber hose PN
                            The part number for that hose is N 0202621. Be aware that even Audi *might* send you the wrong hose. The correct hose is smooth on the outside. The incorrect hose is fuzzy on the outside. It fits but only lasts for a short time before becoming brittle and cracking/failing. Avoid. Only accept the correct hose.
                            More turbo coolant return hose info:http://forums.quattroworld.com/s4s6/msgs/72682.phtml
                            Photo Courtesy of K2exoman on the quattroworld UrS forum.
                            • Michael S2
                              • Dec 2011
                              • 1378
                              Audi will probably want to sell you 1m or 5m when you only need a small length. Roose will sell you both small water hoses in this area for less than £15.
                              1995 Audi S2 Avant
