MFTS delete?
  • Laaf
    • Oct 2010
    • 275
    The right connector for it seems to be 443 906 231.
      • Dec 2017
      • 5984
      Just deleting my MFTS in favour of the Meyle two pin sensor. Can anyone who has done this confirm I need to cut the original plug off and fit two spade connectors or is there a two pin plug I can use. Which wire do I delete?
        Connector is the same as the PAS reservoir level sensor. I have some crimp terminals to suit in stock
          • Dec 2017
          • 5984
          Cheers Alex. I will send you a message
          • johne
            • Apr 2007
            • 1405
            The blue/white wire is the one going to the ECU so is the one to isolate. If it's a 4 wire MFTS they'll also be a black/blue wire which is the 12 volt feed that needs isolating too.
            Blue/brown goes to the temperature gauge
            Blue/yellow goes to the over temperature warning light
              Tractor Dave could you post a quick guide and parts list as mine will need doing at somepoint as the connector has seen better days
                • Dec 2017
                • 5984
                No problem
