Manual Boost Controller
    Anyone tried one of these? http://www.ebay.co.uk/itm/TURBO-MANU...item33590834bd
    I bought one just to play with thinking I might try it on my UR which just has a big spring. At the weekend I thought I'd check it with a mightyvac and set it to 1.5 Bar and try it on the coupe. Got it so it was pumping up to 1.5 Bar then it would let go, next time it wouldn't pum up at all, give it a bang on the table and it pumps up againg utter rubbish!
    So is there actually one of these kind of things that works or are they all rubbish?
  • mike74
    • Apr 2014
    • 615
    Maybe this would be a little better?
    I had one on one of my previous cars and it held 1 bar boost no problem
    In saying that though, you could maybe take your one apart and give it a good clean and a lube....you never know!
    • GazzaG60
      • 4133
      lol
      • sam80quattro
        • Oct 2006
        • 1496
        i had a forge unos on my 1.8t with the t28 on it to get 1 bar instead of .5 and it was spot on.... untill i snapped a pipe off it
          Originally posted by GazzaG60
          lol
          Hehe, are you lolling cos I'm finally trying a MBC after all these years or because I'm so cheap??
            It's amazing how many of these things claim to be the best in the world!
              a bit pricey with the postage..
              http://www.ebay.co.uk/itm/Dawes-Devi...item258f8d9906
              • GazzaG60
                • 4133
                im no fan of mbc. all I can say is set it and don't mess. personally I wouldn't.
                bit of both the lol. as you know I love my boost controllers in comparision with 20 yr old n75 and stock control. I ran mine on stock chip at 1.1bar. fuel afr was good performance much better than stock setup.
                give it a go. check afr atm part throttle take it easy to being with is my advice.
                dawes or manual makes no odds. dawes is just a check valve.
                they are all good value compared with the eboost 2
                • Jonas_R
                  • 3780
                  • Country: Denmark
                  I'm pretty sure I have a Turbosmart MBC you can have it for 30£ delivered in the UK. Under the assumption that I can find it
                  Sleeper S2 Avant +450
                  A6 Avant 2.7t Stage 3
                  Audi S2 Coupe RS2'ed
                  • bikerjim
                    • Feb 2008
                    • 1028
                    I bought one of these too and had a similar problem to you, it would stick a little. I stripped mine down and put a bit of grease in it and it works ok now. yet to try it on the car tho, I was using an airline and a pressure gauge to see how repeatable the actuation was.
                    • bambridge
                      • May 2009
                      • 609
                      Mumby Engineering ???
                      Know this guy(Richard) i make alot of the parts for his Rover gear linkages he sells on ebay ???
                      • GazzaG60
                        • 4133
                        you get what you pay for.
                        like I say id avoid. stick with motronic of buy a proper unit for control.
                        I got lots of hassle for having an ebc. fact is so long as you know the limits and are willing to do without some of the aging safety features you should enjoy the experience
                        • UrS6 - IamS6
                          • Nov 2014
                          • 148
                          • Home: Ireland Current: Western Sahara
                          Any links to a "proper unit" ? Just curious.
                          Thanks either way.
                          • Thuppu
                            • 4115
                            Thanks either way.
                            Australia's leading turbo performance brand since 1997. Shop wastegates, blow-off valves, boost controllers & fuel pressure regulators. Engineered to win.
                            Don't buy it from ebay, china fakes(looks 100% the same) don't work as planned.
                            • GazzaG60
                              • 4133
