RS2 spec live map limiting factor?
  • LHD_Kid
    • May 2006
    • 3695
    Originally posted by driftin jo
    I think you may want to edit that
    • Tonks4x4
      • Nov 2005
      • 3062
      Yes Sal, it did 347hp on the dyno and that was as far as we could take it with the injectors running at nearly 100%.
      Audi Nut!!!
        God bless the iPhone spellchecker eh??
        • Rusty
          • 18953
          Oops.
          • 4WheelDrifter
            • Oct 2004
            • 5773
            • Country: Devon
            #20
            It reminds me of the time I texted a friend, asking about a VW Caddy Maxi, only my phone changed the word maxi, so it had a n and a z instead of the m and x.
            SS
            • andy10v
              • 5996
              Apparently the injectors max first;
              Originally posted by prj
              Originally posted by fish
              Out of interest, what is an RS2 turbo actually capable of bhp/nm wise? Always thought that realisticly an RS2 turbo could make maybe 360bhp/around 500nm?
              About 375/590, but not on stock (RS2) injectors.
              RS2 injectors are not even big enough for a standard RS2 turbo, never mind a hybrid.
              They are 360cc and the max they can do is 1.8 taper 1.35 on boost.
              A standard RS2 turbo can run 1.8 taper 1.45 and a hybrid can run 1.8 taper 1.6..
              RS2 hotside does not flow 400hp without either massively lowered CR or chemical octane boosting/charge air cooling
              So it would be worth fitting 440s for a live map.
              Live map was also to optimise everything to this setup, should be able to get a bit more than a generic chip.
              Buying Albert's turbo and selling the RS2 would not cost any money if getting a live map and would apparently get 450bhp+
              Sold ABY-stock
              • Albert
                • 1500
                • Country: Poland
                #22
                It is not good to run over 80% duty cycle on injectors. Get 550 cc @ 3 bar to be on safe side. You can boost the press to 4 bar if you would need more. Use Bosh 040 fuel pump form old Audi k jetronic to pump the fuel.
                I'm runing my K26 on the race track ... it is responsive look at the videos https://www.youtube.com/channel/UClx...gynbMJGPOVvT4w
                I can make a bet that it is more responsive than the RS2 turbo. This is why I did not get it my self. It has much older compressor wheel in technology aspect.
                AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
                • andy10v
                  • 5996
                  Ok, you have me convinced, I will go billet k26!
                  Sold ABY-stock
                  • urS6Tom
                    • 773
                    Originally posted by Tonks4x4
                    Yes running RS2 injectors maxed to 99.8 duty cycle.
                    I have a set of 1000cc EV injectors to fit and water meth to be used only as a safety.
                    Will be getting round to getting it sorted and mapped in the new year.
                    What's your power target for the RS2 billet with the 1000cc injectors?
                    • Tonks4x4
                      • Nov 2005
                      • 3062
                      Hank has had a few vehicles do between 400 to 420 on pump gas.
                      Audi Nut!!!
