Idle problems with vems
  • nip
    • Apr 2006
    • 1786
    • Home: United Kingdom Current: Abu Dhabi
    Evening all it started a few weeks ago it's started to rev at about 1000-1150, I've pressure tested the bottom of turbo back to the inlet no leaks what so ever all vacume lines tested , I've changed the isv air temp Sensor even the water sender on the back of the head .
    Tonight I changed the Tps and it started to rev at 1400-1500 rpm I've logged it on vems idle should be at 850 but for some reason it's too high any ideas would be much appreciated
  • blackS2
    • Apr 2010
    • 455
    without the log its difficult to guess...
    [__]=oooo=[__]
    • popdemonic
      • Dec 2007
      • 1304
      • Country: Thailand
      have you calibrated the TPS after installed the new one?
      have you downloaded the patch files for CLT and IAT sensor?
      send us some logs and we can see what's wrong with the configs or Hardware problems.
      one of a few I5 from Asia.
      • nip
        • Apr 2006
        • 1786
        I can send the log if you like, I have shown a few people and they say the logs are ok nothing to show the problem
        • popdemonic
          • Dec 2007
          • 1304
          • Country: Thailand
          pm'd
          • jade
            • Jan 2005
            • 1811
            • Home: New Zealand Current: Spain
            I would check the ISV is moving freely, and that you car feel it working, vibrating double check I know you said you replaced it but worth a look
            If you do not post a log cannot help much, need to have a look at your config
            RS 2 580HP
            • popdemonic
              • Dec 2007
              • 1304
              • Country: Thailand
              yeah the isv is occasionally stuck open or some dirt caused the valve couldn't be responded or moved freely.
              i would tried to spray or soaked it with carb cleaner.
              • nip
                • Apr 2006
                • 1786
                I have checked it even with another's isv they both are the same
                • nip
                  • Apr 2006
                  • 1786
                  I will try to recalibrate bathe Tps tomorrow
                  • jade
                    • Jan 2005
                    • 1811
                    If you hold it you can feel it vibrating when the engine is running, that will show its working
                    RS 2 580HP
                    • quattro-nick
                      • Sep 2012
                      • 1746
                      • Country: Belgium
                      you can look for airleaks with some spray brake cleaner or try ignition based idle control in vems.
                      TWINCHARGED power,zero lag
                      AEM W/M injection
                      • nip
                        • Apr 2006
                        • 1786
                        Cheers jade I have done that seem ok
                        • nip
                          • Apr 2006
                          • 1786
                          I have tried all hoses checked and pressure tested
                          • nip
                            • Apr 2006
                            • 1786
                            also I started it up drove about half a mile put my foot down no boost!!!! turned the car off then back on again and full boost back to normal
                              MAF connector
