boost lag and fuel economy question
Thanks. I will do boost test once I get MAF hose, and I'll check exhaust for blockage in a mean while.
How would you check N75 for leaks?
While I wait for MAF hose I will go over PCV system and check the valves and piping again.
I had a hole in my MAF hose when I first got my 3B, it had rubbed through on the back of the headlight shroud. It wasn't running right.. I also had a leak in the N75.Leave a comment:
If you have a leak in the MAF hose of PCV then you will be just drawing in unmetered air and the ECU will only be trying to add fuel to combat a lean situation, the amount of adaption will still change depending on how big the leak and how much throttle.Leave a comment:
I'll hook up my spare tyre and boost test, I've ordered MAF hose too should arrive next week at some point.Leave a comment:
If you have a "boost" leak then the ECU will try to adapt as you go from off-boost (cruise = vacuum so drawing in unmetered air) To on-boost (boost = pressure so metered air escaping) This means you get a stumble as you go from cruise to boost before it adapts.
If you disconnect the Lambda it cant adapt so no stumble, just rich all the time
That's the theory, of course you have to do the boost leak test to find out if you have a leak. It will be a small one, if it was a big one you'd get a code or an "overboost" fuel cut!Leave a comment:
What I will try to do is undo downpipe bolts (where it attaches to cats) to have a gap and then go for loud test drive and see if that helps.Leave a comment:
Don't have access to air line. Not planning to go south any time soon.Leave a comment:
Well, if fuel consumption dropped I think you can assume lambda is probably working ok. Lambda isn't used on full throttle
Lambda is ignored at WOT anyway.
Do a boost leak test. Properly with an air line.
When are you back down South? How about ADI?Leave a comment:
I mean fuel consumption dropped right down. But first/second gear it felt nippier.Leave a comment:
It will run rich with lambda disconnected the ECU will use default safe values. I would image it will also pull timing to be safe.Leave a comment:
When I request full boost (i.e. fully press throttle) nothing happens for good second or two at about 2000 rpm in 3rd gear, of course it's less noticeable in lower gears and higher revs.
Was doing about 75mph on my way to brother's and I floored it in 6th (3000rpm) it still has a lag (unlike when I was coming back from you) and then it boosts and goes but occasionally I can feel car shake slightly or being slightly sluggish.
It's hard to explain.Leave a comment:
