my twincharged project
  • quattro-nick
    • Sep 2012
    • 1746
    • Country: Belgium
    #136
    I tried my best chris
    I'm curious about the sound on the road and under full load
    TWINCHARGED power,zero lag
    AEM W/M injection
    • jogi730
      • 2335
      Usual good work going on there
      Audi 90 quattro (Typ 85)
      20v turbo conversion
      • Thuppu
        • 4115
        1 short and 1 long Simons 3.5" muffler. I have the same setup, and it's really quiet hahaaa!
        Looking good though.
        • quattro-nick
          • Sep 2012
          • 1746
          • Country: Belgium
          #139
          just back from my first testdrive after these modifications and everything is looking good except for the boost control
          still making 2.5 bar boost on full load,maybe my waste gate isn't big enough?
          i believe it is a tial 38mm,i've noticed by a pressure test with the new diagram that it is still leaking,probably on the valve axle
          when i'm sure that a 38mm is big enough i wil buy a new 38mm waste gate
          the sound from the exhaust is great
          almost ready for the dyno
          AEM W/M injection
          • quattro-nick
            • Sep 2012
            • 1746
            • Country: Belgium
            #140
            so,i was thinking,the tial waste gate have 2 springs inside,maybe i can remove one(the lightest spring) and see what the reaction is.
            only that can happen is when the other spring is to light the boost is not high enough,correct?
            AEM W/M injection
            • Thuppu
              • 4115
              Isn't 2.5 bar just good?
              Yes, looser spring will open the WG more easily. What boost control do you use?
              • quattro-nick
                • Sep 2012
                • 1746
                • Country: Belgium
                #142
                vems-new n75valve-tial waste gate
                i never had problems with this setup but i changed turbo from gt30 to gt35
                around 4000 rpm i make 2.0 bar boost and then you hear the waste gate make a fluffer sound (driving with window open)
                around 5500 rpm te boost goes up with the rpm
                in the past my vems setting "boost vs rpm curve" stands max on 2.0 bar the hole line
                i have change this grafic on 5500 rpm-7000 rpm and put it on 1.6bar but still 2.5 bar
                AEM W/M injection
                • diesel des
                  • 3896
                  #143
                  What happens if you disconnect n75 and connect wastgate direct to boost source? Nice exhaust setup.
                  • quattro-nick
                    • Sep 2012
                    • 1746
                    • Country: Belgium
                    #144
                    I have not tried it yet des but tomorrow I'm going to disassemble the wastegate and see where the leak comes from or is this normal that you can not do a leaktest with a handpump?
                    AEM W/M injection
                    • quattro-nick
                      • Sep 2012
                      • 1746
                      • Country: Belgium
                      #145
                      today i have solved my boost problem
                      first problem was that the waste gate did not went fully open because the diagram came against a plug in the upper part of the waste gate house
                      the second problem was the n75 valve.
                      when I put the waste gate hose directly to the turbo the car was making 1.2 bar boost so i knew that the waste gate was good and big enough
                      My conclusion was that the valve was a restriction so i take the valve and i drilled the hole on the pressure (turbo) side a little bigger and did a new testdrive
                      yes,the car was making 1.4bar boost and now i can control back the boost with vems settings
                      AEM W/M injection
                      • diesel des
                        • 3896
                        #146
                        Cool. Now wind that boost back up again lol
                        • quattro-nick
                          • Sep 2012
                          • 1746
                          • Country: Belgium
                          #147
                          i have set boost on 2.0 bar for now,wil see of i can go higher on the dyno,maybe 2.5 bar is possible with the gt35
                          intake temp is not a problem with the W/M injection,i had 10°c on full load while testdriving on 2.0 bar boost,
                          AEM W/M injection
                          • LHD_Kid
                            • May 2006
                            • 3695
                            #148
                            Excellent news!!!!
                            Looking forward to seeing it again - and hearing the new exhaust!
                            • diesel des
                              • 3896
                              #149
                              So how fast is it?
                              • quattro-nick
                                • Sep 2012
                                • 1746
                                • Country: Belgium
                                #150
                                it's very fast but not een big difference with my old setup i think,only gt30 turbo(520hp-635nm).maybe this is just a feeling........
                                the car feels faster on higher revs now with the gt35,o well,the dyno will tell me soon
                                i hope to make some 550-600 hp,about torque,i dont know
                                will post the results when i have it
                                i'm still thinking that my baypass valve coud ba a restriction,it's 70mm outside like the throttlevalve on the intake but i just gonna wait for the dyno
                                AEM W/M injection
