No boost after engine/turbo upgrade
  • gmac78
    • Oct 2009
    • 928
    • Home: Scotland
    Hi Guys,
    Looking for some advice on my no boost issue.
    My 3B has been under going a fair amount of work lately. Basically it's been converted from distributor to ABY ECU, TFSI coils etc. Also i've had the head off fitting new valve stem oil seals, lapping in the valves, polishing the exhaust ports, uograding the headgasket, fitting an RS2 exhaust manifold, RS2 turbo, RS2 intercooler, 3" exhaust etc etc, basically full RS2 spec but using 3B cams.
    Today it was finally all ready and back together except for no MOT. However, i could wait no longer and took her out for a wee spin to sample the new found power.
    I've had the car running plenty of times in the garage but only idling/ reving up, today was the first spin on the open road under load.
    Fired her up at the house and it seemed to take a little longer to start than normal. Normally fires into life first turn. However once started it was ticking over no probs with no issues.
    I let her warm up a bit then ventured out on the road, took off slowly just cruising up the road, so far so good. After a few miles i decided to slowly apply some boost only to find i'm getting spring pressure of around 0.4 bar, then the blink code light on the dash started flashing. I carried on for a few miles then returned home just playing with spring pressure alone. I didn't have VCDS with me so read codes via the blink method.
    Code 4411 was coming back for open or short circuit on Cyl 1 injector. Found this strange as it there was no miss in it and ran fine. Checked the wiring to injector one in case i had not connected it properly, gave it a wiggle etc. Nothing untoward found, hmmm?
    Went for another spin, same again, just when boost should start to build from normal spring pressure of 0.4 bar the blink code light on the dash started to flash. Back to base to check codes and this time 2113 was coming up, Hall sensor in distributor.
    Now then, one wire i have not yet connected following the 3B to ABY ignition system upgrade is the VSS wire that connects in behind the stereo. For some reason i was thinking that had something to do with launch control so not needed. Perhaps i am completely wrong on that one?
    Anyhow, the car seems to go nice and smooth with no misfire etc just no positive boost building over 0.4 bar. Had a quick look in the engine bay for any loose fittings, connectors, i.e N75 etc and all appeared connected.
    Am i missing something simple here?
    Any help greatly appreciated.
    Regards
    Gordon
  • piotr
    • Jul 2012
    • 1470
    What software do you run?
    • gmac78
      • Oct 2009
      • 928
      • Home: Scotland
      V Stream from S2Central.
        Check your ground wires are good and tight to the inlet manifold
          Unplug MFTS and have another try
          VSS behind stereo is only there for GALA so no problems there, as long as the ECU has its feed
          • gmac78
            • Oct 2009
            • 928
            • Home: Scotland
            Had a quick look at the inlet manifold grounds, seemed tight enough. Could try the MFTS, was working ok previously but you never know. Take it they don't throw codes?
              F76 Multifunction Temperature Switch R&R Info (with Cross Links to G62 Coolant Temp S
              Nope. And a failed one fails safe, "telling" the non-AAN (i.e. 3B, ABY and ADU) ECU that coolant temps are hot, leading the ECU to shut down active boost control, i.e. WG spring pressure only.
              "The F76 Multifunction temperature sender has different functions in the ABY and ADU than the AAN. For all three, the MFTS is the sender for the temperature gauge in the instrument cluster. On the ABY/ADU, the MFTS is also connected to the ECU via pin 46 of the T55 ECU connector. Using this pin as a high temp alarm (> 119 C) - the ECU cuts off active boost control as a safety measure. However, for the AAN, pin 46 is not used, as indicated in this Motronic 20VT AAN pin-out. On the AAN, the MFTS F76/R pin connects to is the HVAC/climate system to shut off the compressor during such high temperatures. In addition, the MFTS is connected to the coolant temperature gauge."
              REFERENCE: http://forums.quattroworld.com/s4s6/msgs/22584.phtml
                Mine was playing up a while back for no apparent reason so I disconnected the signal to the ECU at the T8 connector on the bulkhead
                IMHO if you are dumb enough not to recognise an overheating engine & back off the loud pedal you deserve a fooked engine
                • Rusty
                  • 18953
                  This was an issue on a mate's car and the previous owner had replaced half of the car to try and cure it
                    Is your dizzy and cam timing definitely spot on? Everything on the marks?
                    Check WGFV is working and not stuck. (Open bonnet, blip the throttle by hand and you should hear/feel the WGFV clicking)
                    • mike74
                      • Apr 2014
                      • 615
                      Are you sure the N75 is plumbed up correctly?
                      Another thing to check is the barometric sensor (assuming 3B's had it?) ala:
                      • EBR
                        • Jan 2009
                        • 64
                        • Country: Iceland
                        Are you using an OE crank pulley for the timing belt? I had an OE crank pulley that broke and turned a few degrees on the crank. When it happens the hall sender on the head doesn't sync with the one on the flywheel and that makes the car go into safe mode. When it happened on my car everything seemed normal, but it went into safe mode when it was reved over approx 4k rpm.
                        Audi S4 20VT 11.453@121.62
                        • gmac78
                          • Oct 2009
                          • 928
                          • Home: Scotland
                          Hi Guys,
                          Didn't get much of a chance to play with it today but did try a few things.
                          Started the car but was slow to spring in to life again, the car has never been like this, always started first turn.
                          What might be of interest is that i had the ECU out a few days ago getting the correct R201 resistor fitted, as previously i had two resistors in series, which measured 5.6k ohms instead of the correct one which measures 5.5k ohms. The difference is small but thought it best to put the correct resistor in for peace of mind. At the same this was getting done a wire to the 3 MAP sensor had broken it's solder and needed repairing. All went well according to the TV repair guy doing the soldering, it was him that had fitted the original two resistors and MAP sensor a couple of months back.
                          It was after refitting the ECU with RS2 V STREAM chips instead off the TS Tuning ones that were in it previously, that this problem has started. I also fitted the correct RS2 injectors instead off the 034 replicas which were in it. I thought i may as well put the correct injectors since them were sitting on shelf.
                          Anyhow since doing all of this i am now getting a fault code which is activating the blink light on the dash, and i'm guessing is the cause of the no boost issue??
                          The fault code stored in VCDS is
                          00515 Camshaft position Hall sensor G40
                          01-10 Signal Shorted to plus- Intermittent
                          During the few spins i had of it today it was once boosted up to 1 bar, this was with the MFTS still connected.
                          Disconnected MFTS and could not get any more than spring pressure boost.
                          My paranoid mind is thinking something could have been damaged in the ECU whilst fitting the R201 resistor and re-soldering the wire on the MAP sensor?
                          Up until this work a couple of days ago the car would start first turn, and could be revved no bother without any blink codes activating. I haven't touched anything else on the car.
                          What do you reckon to that guys? Where next?
                          Possible loose wire on the ECU following the 3B to ABY conversion. Doing that pin swap can be quite tricky! Or is there something else more obvious?
                          Thanks for all your input guys.
                          • gmac78
                            • Oct 2009
                            • 928
                            • Home: Scotland
                            I didn't check timing today as it is only been a few weeks since all that was put back together. It was all spot on at the time so doubt anything has gone wrong there, i used a new crankshaft sprocket so hoping thats not failed already?!!
                            N75 is all plumbed up correctly too. Previously the car could be idling/revved and no blink light coming on. Now as soon as you start the car and rev it up to around 3-4k the blink light will illuminate and throw the G40 code. The hall sensor could be failing or the wiring to it loose somewhere but i've just checked the 3B to ABY pin out and pins 8 & 12 are not disturbed during the process so they should be ok. I'll need to double check though.
                            • twoqu
                              • Sep 2003
                              • 3103
                              Well you say that the problem started when you swopped chips so that looks a potential clue. Whether its a SW or HW issue needs to be eliminated. Is the V stream a RS2 version or for an S2 RS2 conversion. There will be a difference to account for that resistor which then needs RS2 base SW not S2 base.
                              If you have the old chips you could just swap them back as a sanity check!
