Stroker oil pump failure
  • curamrdan
    • Sep 2014
    • 91
    • Country: Czech Republic
    • curamrdan
      • Sep 2014
      • 91
      I think this is an another second valve, this one is on top. I cannot blow by mouth throught this middle hole, this valve makes it closed - oil flow from inside the filter must open this valve. Or its just some missunderstood - as i try to blown in by outlet - anti drain valve comes to play.
      • Bowie69
        • Nov 2013
        • 2675
        Originally posted by quattro-nick
        that's a bypass valve which opens when the filter is clogged
        Err, non-return valve, isn't it? Unless I am missing a particularly cruel joke.
          There is often a bypass valve too, which prevents oil starvation if the filter is clogged, or even at start-up with really cold viscous oil
          • Bowie69
            • Nov 2013
            • 2675
            Oh OK Thanks, edumocated now
            Amazing what google turns up.... and then gives more reasons for more often oil changes, not running too thick an oil, not running too high RPM when cold etc.....
            • AndyP
              • 6049
              Originally posted by curamrdan
              AAT pump and ABY/AAN? pump looks inside the same. Same colour of material, no different details inside. Measured some clearance(im not quite sure what, im not engine builder) and builder decided to use AAT, but its was just barelly better. Idea was it whole life drive just under 4000rpm, and if items are the same, will be more "fresh" - i know it can sound bit simple, but...
              I've stripped a few AAT/AEL oil pumps and have never spotted anything different to the Petrol ones, I really don't see Audi making the TDi pump out of different materials.
              • diesel des
                • 3896
                #22
                Are the gears the same size?
                • curamrdan
                  • Sep 2014
                  • 91
                  #23
                  Yes, dimensions ect are the same, no visible difference as i noted before.
                  Add to oil filter, i accidentaly found in some thread, diesel des you are used Mahle OC264 and found this:
                  same dimensions as my OC47 , but no "unknown" valve on filter outlet = free flow for oil.
                  • diesel des
                    • 3896
                    #24
                    Interesting. So if the tdi oil pump is basically the same as a 20vt pump why is oil pressure less on a striker when using tdi piston cooler jets?
                    • Thuppu
                      • 4115
                      Many people use diesel squirters without pressure problems, so the possible pressure issues must be caused by somehing else.
                      • diesel des
                        • 3896
                        #26
                        I have heard a few people have changed from tdi to 20vt jets and added between .5 and 1 bar oil pressure at idle. On my urs4 I use tdi jets and get 1.5 bar oil pressure at idle when hit. When very hot maybe 1.2 bar and it starts to get worrying.
                        • curamrdan
                          • Sep 2014
                          • 91
                          #27
                          I tested both jets, and its also written in other threads on forum. 20vt jets opening at 1bar, tdi opens around 0.4bar. So idle pressure can be affected by this slightly. And of course some of old jet can be jammed or faulty, then every theory is useless.
                          • _ShurikeN
                            • Mar 2010
                            • 733
                            • Country: Russian Federation
                            #28
                            I probably not touch the backplate now
                            I have heard an opinion that oilpump dies very quickly without that black antifriction coating on the backplate. Not personal experience. It was just about audi 5-pot motors.
                            ...if I ever have to chose a better oilpump out of several ones withoout measuring tools, I look at the condition of this black coating at first.
                              It's not the old head stud issue by any chance?
                              • curamrdan
                                • Sep 2014
                                • 91
                                #30
                                Found that rubber boot/manifold on suction pipe/oilpickup , is the same(same number) on TDI and 20vt, but pipe itself is slightly different, TDI(034115251G) goes cca 2mm more to bottom = touching alu 20vt oilpan. The 20vt pipe (034115251J) is even equal with oilpan bottom, maybe 1mm clearance. There is still enought space for oil with rubber pressed on bottom(calculated area), but i dont want experiment now = Was used the TDI, now will be used 20vt.
                                I think coating on pump backplate is not kind of hardening ect, as seen on picture, there is some wear on pump plate, which will be used, in same place where damage happends on first pump. But i will not touch it, just let it mount as is. Dont have any other pump to choose, now.
                                And last change, will be the oilfilter without outlet valve. Probably OEM MANN.
                                newsh: dont know what are you talking about. I just remmeber, TDI has 12mm bolts, so we must drill head for that diameter + one hole is used for oil, so it was enlargered bit more. Is it what you mean? Using cheap universal M12 inbus reinforced 12.9 bolts, cutted to fill almost whole thread available in block(measured).
