Hello everyone.
Some of you might reconize my screen name... I've gone through alot with these cars with transplants and everything else. I've decide to work my way out of this hole I dug a bit faster.
This meant scraping my second coupe project(now parts car) and sourcing a 1994 B4 platform audi 90 quattro sedan. The problem is the fact that it has a v6 engine in it and not a 5 cylinder setup. Small price to pay for a really nice car.
I've got a couple of choices. I can either cut and weld the engine bracket mounts that are attached to the block. Which I am thinking of leaning towards doing to fix this issuse. I could also weld on 5 cylinder brackets onto the frame rails. My sawzal broke and I am currently having a little issuse getting them out of the coupe. However i took a break from it and will attack them at another time.
I was curious if VAG still sold the 5 cylinder engine mounts and radiator mounts? I doubt it. I know you can't source them here in the states.
I figured I post and ask some questions.
Josh
Josh
