What's still avaliable in europe> weld on engine mounts?
  • Josh-stateside
    • 741
    Hello everyone.
    Some of you might reconize my screen name... I've gone through alot with these cars with transplants and everything else. I've decide to work my way out of this hole I dug a bit faster.
    This meant scraping my second coupe project(now parts car) and sourcing a 1994 B4 platform audi 90 quattro sedan. The problem is the fact that it has a v6 engine in it and not a 5 cylinder setup. Small price to pay for a really nice car.
    I've got a couple of choices. I can either cut and weld the engine bracket mounts that are attached to the block. Which I am thinking of leaning towards doing to fix this issuse. I could also weld on 5 cylinder brackets onto the frame rails. My sawzal broke and I am currently having a little issuse getting them out of the coupe. However i took a break from it and will attack them at another time.
    I was curious if VAG still sold the 5 cylinder engine mounts and radiator mounts? I doubt it. I know you can't source them here in the states.
    I figured I post and ask some questions.
    Josh
  • Jonas_R
    • 3781
    • Country: Denmark
    Well as far as i know, audi in germany has spares up to 15 years or something.
    /Jonas R.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
    • NoNonsense
      Forum Sponsor
      • Apr 2004
      • 673
      Josh,
      You can get those items still. If you recall, B4turbo from AW sourced proper engine mounts for the AAN engine he put into his 12v V6 chassis.
      I could be mistaken, but I believe you simply need RS2 brackets (perhaps the same as S2 sedan/avant) brackets.
      I'm currently doing a similar swap, but I'm retaining the V6 radiator.
      Joe "NoNonsense"
      axis motorsport
      joe@axismotorsport.com
      "At the end of the game, the king and the pawn go back in the same box."
      • Fat Audi 80
        • 10547
        VAGparts should be able to advise availabitlity if you know what you want.
        I was under the impression most parts for Coupe's are still available....
        Cheers,
        Steve.
        The Perfectionist
        • Josh-stateside
          • 741
          Unfortunately Miles aka B4turbo used the stock mounts with some small chunks of metal as spacers/adapters. Unfortunately I haven't seen where the passenger side aka turbo side engine mount sits in comparison to b3 platform or URS4 platform engine mounts.
          I have three spare 7a block and one is empty. Basically my plan right now is to pull the v6 engine out of the sedan and install the bare bottom end to the transmission. Where ever the mounts sit in comparision to bolt on v6 engine mounts will allow me to make my decisions.
          I have a funny feeling I will have the car flatbed with the engine pulled out to my friends shop to have them cut up the stock engine brackets that mount to the engine to make it work properly.
          I'm still interested on sourcing prices on the 5 cylinder engine mounts that weld to the frame.
          Josh
          • Jonas_R
            • 3781
            • Country: Denmark
            Josh,
            If you got the part numbers? i can call my parts pusher at Audi in Flensborg Germany and ask if he has the parts that you need.
            /Jonas R.
            • fendent
              • 145
              • Country: Switzerland
              /Jonas R.
              That´s a laugh. Don´t ever expect that to be true. Not even for parts that are needed to keep the car on the road! I´m sure everyone can tell his own story about that.
              Marcel
              ________________________________________
              current: RS2, + A2 TDI 3L
              Favourit: Coupe Quattro Typ 85 or 859. I had one.
              If you know someone in Switzerland selling a Ur-20V --> tell me.
              • Josh-stateside
                • 741
                Josh,
                /Jonas R.
                I'll see what I can do about getting part #s.. My computer crashed a half year ago and I lost e*K*.
                I'll ask around on the forums for help.
                thanks
                josh
                • Jonas_R
                  • 3781
                  • Country: Denmark
                  Yeah well, just laugh then, but last i spoke to my dealer in germany that was what he told me. Why should he lie to me? and sofar i have not had any problems sourcing any strange bits. Else there are a lot of used parts stores in germany, guess if you have the part nr. they can surely get it.
                  /Jonas R.
                  • porkkis
                    • 1994
                    Jonas, if you think everything is still available - try to ask about the seat clothing. About all interior fabric stuff for coupe is dropped.
                    Josh,
                    B3 LH/rad bracket 893 803 029 (to end of MY91)
                    B3 LH/rad bracket 893 803 029 A for S2 (to end of MY91)
                    B3 LH/rad bracket 8A0 803 029 B (from start of MY92)
                    B3 RH bracket 893 803 030 (to end of MY91)
                    B3 RH bracket 8A0 803 030 C (from start of MY92)
                    B4 LH/rad 8A0 803 029 B
                    B4 RH 8A0 803 030 C
                    I do not know what the differences are but I'm pretty certain they are intechangeable.
                    They are around 150 euros each.
                    • S2 Ant
                      • 3682
                      Josh if you let me know the parts you're after i can also look up availability and pricing for us in the UK.
                      I believe parts are made available for up to either 15yrs or 20yrs, i know a lot of MK1 Golf stuff is only in the last couple of yrs becoming obsolete, ive yet to come across anything else with any problems, all of us should be safe for time to come yet
                      Ant
                      2011 Kawasaki Z1000
                      • Jonas_R
                        • 3781
                        • Country: Denmark
                        Yeah of course you cant get fabric, but you should be able to get mechanical parts. But hey just refering what i heard from my german parts dealer.
                        /Jonas R.
                        • ThatGUY
                          • Sep 2004
                          • 794
                          Alexander from Europrice was going to get me a set.
                          Andrew
                          //-\\ ((_)) //)) //
