Awful running
  • dan_b
    • Sep 2003
    • 3670
    Awful running
    Argh.
    Last night, drove my car round the South Circular- first time I've driven it for about a week; last time it was absoloutely fine. Last night, absolutely awful.
    Problems: what can only be described as not running remotely right.
    Slightly lumpy tick-over.
    Hesitant acceleration, low on boost at all throttle positions.
    When the revs drop say, when changing gear, it very reluctant engine pick-up after bringing the clutch back in again - almost as if it's trying to stall. Makes for very jerky progress!
    Holding the car at a constant RPM (say 3000), you can actually feel the car fluttering, it won't maintain constant speed and engine revs.
    I've noticed a few threads round here in the last few days about running problems. I'm assuming I should be looking at:
    Dirty MAF
    Idle Stabilisation Valve
    Split wastegate diaphragm
    Boost leak
    Any other usual suspects? I don't have access to VAGCOM, but would something like this be likely to produce fault codes?
    How do I check all the above?
    Sparkies were changed about 5000miles ago. Have a full tank of Ultimate. Car ran beautifully last week.
  • Mikes2
    • 1704
    Could also be ignition related. Spark plugs, leads, coil, rotor arm etc
    Mike
    http://www.s2-audi.co.uk
    • dan_b
      • Sep 2003
      • 3670
      Good point. Grh.
      Is my best bet to try and pull some fault codes? How do I do it without VAGCOM?
      • Mikes2
        • 1704
        S2central.net has a guide on pulling codes
        Mike
        • martinjs
          • 3205
          Definately check your plug leads Dan, They can crack at the ends which fit over the plugs causing misfires, also check that your plugs are tight, they can have a habit of working loose especially no 5 cyl.
          Could be the old favourite boost leak of course.
          martin
          • Keeper of The Kitten
            • Dec 2003
            • 2317
            Weather's been hotter than of late, def hotter than last week - did you get immediate problems or something that might be heat soak related?
            Just a thought!
            __MDC__
            Martin Cutting
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              I had a problem which sounds similar to this. The engine was only running on four. It turned out to be one of the connectors on an injector had broke.
              To find which cylinder was the culprit I unplugged each one in turn. So unplugging the wrong one made it run on three, and the right one made no difference.
              SS
              • BeckyA4
                • Dec 2004
                • 9
                Hey Dan, it sounds like a massive boost leak to me. Like a pipe split right open. Can you hear any whooshing noises when boosting?? Do you have aboost gauge in the car? Whats the reading when at idle?
                1996 A4 1.8T Sport
                Kingfisher Blue MRC Tuned 205BHP
                Mostly good on fuel, expect when driven by Tom :mischeif:
                  Becky should get on here more often she's talks more technical sense than her boyfriend
                  • S2 Ant
                    • 3682
                    I was just thinking that from another thread
                    Ant
                    2011 Kawasaki Z1000
                    • Mikes2
                      • 1704
                      if it's lumpy at tickover it won't be a boost leak
                      Mike
                      • 4WheelDrifter
                        • Oct 2004
                        • 5773
                        • Country: Devon
                        If it's a massive boost leak as Becky says, it could also be a vacuum leak at idle.
                        SS
                        • dan_b
                          • Sep 2003
                          • 3670
                          It doesn't sound like a boost leak - there is no noticable whooshing or hissing noises (well no more than usual with a cone on instead of the 3B airbox).
                          It happened literally from turrning the key on Thursday - which was a significantly hotter and more humid day than any we've had this year. Engine and oil temps were fine on the gauges.
                          I'll start with the obvious and check the HT leads and plugs - I might be having a visit from one of our fantastic S2forum members this weekend to give it a VAGCOMing, so maybe that might illuminate it if it's not as obvious?
                          • audiman
                            • 4827
                            Why not?? Try pulling a hose off.
                            Tom C - www.rcmr.co.uk
                            Audi UR Quattro
                            Audi 100 C3 2.0 5 cyl 115ps
                            Audi B5 RS4 645ps 911nm
                            • dan_b
                              • Sep 2003
                              • 3670
                              Ok - took the ISV out - rather black in there, so gave it a good squirting with WD40.
                              Took the MAF off, the wires are all still nice and clean.
                              Took all my sparkies out - 1, 3 and 5 were all what I would describe as "loose". I took a picture -all 5 are in this same condition, they look ok don't they? I changed them about 8,000 miles ago. Plug leads look ok, no visable signs of damage or any arcing or anything.
                              So, after doing all that lot - tick over seems smoother, but on the road, still getting this hesitation feeling after gear changes. It doesn't feel like the hesitation issue that Honahon had (which turned out to be a dodgy coilpack, and from that I'm extrapolating that to mean that I'm firing ok on all 5-cylinders), so what else could it be? Couldn't see any visable signs of any split hoses, and it definitely is not sounding like there's a boost leak - no noticable hissing our air escaping sounds.
                              Any other ideas? How do I check the wastegate diaphragm? Will be checking out VAGCOM for fault codes this week...
